Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum data shortcut version
    • Sign In
    • State Suggested Answer
    • Replies 3 replies
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 2200 views
    • Users 0 members are here
    • version control
    • Data Shortcuts
    Luc Poulin
    Offline Luc Poulin over 4 years ago
    We are expanding the use of versioning to files that feed the data Shortcut project ( DS-Project) and to the project it self (.CivilDSProj)
    Maybe we are doing something wrong as we begin to explore.
    For some reason the DS does not update at the end of the consumption chain.
    DS Feeder ( version B) » DS-Project » DS Consumer » Xref into the master document
    In the DS Feeder file, designer use the mask command to hide the last end of the track
    In the master document we expect to see the end portion of the track being update and mask, which is not the case
    In order to see the application of the mask, we had to create a duplicate entry of the track in the DS-Project
    An consume that new track entry
    The DS-Project consume only the version B of the DSA Feeder, which for me should have update the DS with the new information of the track ( apply the mask to the end of the track).
    Upon investigation we find
    The mask option of the track did not propagate to the original entry I the DS project or was stuck in some sort of caching and we have no idea how to force any cache information to be refresh.
    • Sign in to reply
    • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Mon, Jun 10 2019 12:41 PM
      Update I case someone experience the same issue.
      We ran some other tests and find out.... we need to delete the local cache copy, force a refresh which will create a broken link inside C3D
      Back to PW, manually force the copy-out.
      Back to C3D, repair the broken link
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Phil Conard
      0 Offline Phil Conard Mon, Jun 10 2019 8:46 PM in reply to Luc Poulin
      Hi Luc, are you familiar with the PW Datashortcut project editor tool (start>Bentley>PW>Tools>PW Datashorctut project editor)? It's a tool that will open the .civildsproj file and assist with repairing any errors in the project so you can repath broken links. Also, Civil 3D has it's shortcutshistory.xml that makes Civil 3D load the last known project. If that path still exists on that computer, Civil 3D will resolve that first. You can either blow away that XML or change the path so that Civil 3D can't resolve it.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Tue, Jun 11 2019 12:50 PM in reply to Luc Poulin
      Thank you Phil
      Yes I'm aware of the Project Editor.
      In my case I did not have any error. I force that error ( by deleting a file) so I can force the system to re-read the file to load the correct information of the track element contain in the short cut
      That .xml info is interesting,  will keep that in mind
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
