Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Is there a method to use file synchronize across datasources?
    • Sign In
    • State Not Answered
    • +2 person also asked this people also asked this
    • Replies 8 replies
    • Subscribers 63 subscribers
    • Views 1716 views
    • Users 0 members are here
    • Administration
    • Bentley ProjectWise
    • datasources
    frank henderson
    Offline frank henderson over 4 years ago
    Wondering if there is a method to use delta file transfer between datasources?  I would make maintaining large environments with Project Templates, design standard documents, instruction sets, etc. easier to manage if there was a method to choose certain folders to be synchronized between datasources. I was just wondering if this feature exists or has there been a thought to implement such?
    Frank
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Jun 21 2019 9:47 AM
      2 methods:
      1. ICS for PDF (despite the name) can sync files to other data sources. Basically you distribute files without rendering them.
      2. Powershell scripting. This is trickier because it isn't a single command, you'll have to export the files locally via powershell then import them into each data source. Also if you want to copy attributes from environments you have to script that too (ics can do this, even mapping attributes between different environments.)
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Joe Rodriguez
      0 Offline Joe Rodriguez Thu, Oct 24 2019 6:14 PM in reply to Kevin van Haaren
      Kevin, is there any documentation or do you have a guide/steps on method 1 above? I need to sync files from one data source to another data source.
      TIA
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Fri, Oct 25 2019 8:07 AM in reply to Joe Rodriguez
      Jrod
      Kevin probably have better insight than me but here the big lines
      I create a saved search to collect the documents ( find it more practical), in my case I have a properties name Replication that users need to check or uncheck
      On the Integration server being the source ( the one hosting the document to be replicate) create under Rendition an output profile. There is few options, you may need to do some test to get the desire results.
      On the ICS server associate to the source, create a new job definition, select the server that host the documents
           In the Input files tab select the Output profile you create earlier
           In the rendition settings, select Do not generate  renditions
           In the Distribution Settings tab select the Output profile create earlier ( click the white page icon)
      Launch the replication in manual from the ICS
      That should help you get start. Test with a small dataset and growth the replication dataset or do multiple one the create a schedule
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Joe Rodriguez
      0 Offline Joe Rodriguez Fri, Oct 25 2019 11:48 AM in reply to Luc Poulin
      Luc, thanks for your help.
      I have read about the saved search process to gather the documents but i'm unclear about how its used (defined) in iCS source dialog to tell iCS which documents to sync.
      Also, I don't have access to iSC server since we are Bentley hosted so I have to do everything from PW Explorer and PW Admin.
      TIA
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Oct 25 2019 12:00 PM in reply to Joe Rodriguez
      might talk to Bentley managed services about ICS. My understanding is there are some hoops to hop through but you should be able to work on an ICS server (we aren't hosted, just been talking with them).
      I think the next update of server stuff will add off-server ICS management.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Tue, Oct 29 2019 10:09 AM in reply to Joe Rodriguez
      As Kevin mention, you may have to wait until the next update, else the Third step ( on the ICS Sever)  will not be accessible to you ( sorry)
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Luc Poulin
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
