Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum workflow error -50001
    • Sign In
    • State Suggested Answer
    • Replies 2 replies
    • Answers 1 answer
    • Subscribers 59 subscribers
    • Views 1028 views
    • Users 0 members are here
    • Projectwise Explorer
    • administrator
    • Workflow
    • Attributes
    • Rules Engine
    Danillo Guimaraes
    Offline Danillo Guimaraes over 4 years ago
    Hi guys,
    I'm currently struggling with an error that's happening at a certain step of my workflow.
    When I try to approve my document to a certain stage, I get this error:
    But the Attribute is created and configured correctly.
    I noticed that this attribute is currently being used as a trigger to a select statement for another attribute:
    I tried to make that Attribute editable and manually change its value, and also got this error:
    But if I remove this attribute (REV_TYPE) from the trigger of the REV_NEW attribute, I can edit it and the workflow works.
    Also, if I add another attribute as a trigger for the REV_NEW attribute, this new attribute also display an error when updating.
    This is the place in the rules engine where the attribute is being updated:
    Can anyone help me with that?
    I tried all I could think of, and nothing seems to work.
    Thank you!
    • Sign in to reply
    • Cancel
    • Mick Inkster
      0 Offline Mick Inkster Fri, Jul 19 2019 10:57 AM
      Hi Danillo,
      The error is asking for "REV_TYPE" and the dialog for the attribute is called "REV_NEW". Can you check if you have REV_TYPE somewhere?
      Mick
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Danillo Guimaraes
      0 Offline Danillo Guimaraes Fri, Jul 19 2019 10:59 AM in reply to Mick Inkster
      Hi Mick,
      Yes, I have the REV_TYPE attribute.
      I shared the REV_NEW values as it's where the REV_TYPE is used as a reference, and if I remove this reference then I can update its value without any error.
      Thank you!
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
