Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Extracting absolute filelocation from Projectwise
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 60 subscribers
    • Views 788 views
    • Users 0 members are here
    • attribute
    • Exchange
    • MicroStation
    • ProjectWise
    • integration
    Ole Bro
    Offline Ole Bro over 4 years ago
    I'm working with the integration between Projectwise and Microstation - Setting up a title Block. In the title block I want to show the absolute file location, if anyone should be in doubt where to find the file in Projectwise.
    I have looked at the properties available under Attribute Exchange Rules / Microstation Title Blocks / Bindings.
    There are a lot of Properties to bind to my File Location Attribute, but non of them containing the absolute filename.
    I have found the FolderCode which contains the DMS folder ID. The FolderName which contains the parent folder name. Non of the properties I have tested contains the path showed in the General Properties tab as shown in the inserted screen dump.
    Is it possible to get access to this information in a way so I can insert it in my title Block ?
    Thanks In advance.
    Ole Bro
    • Sign in to reply
    • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Tue, Jul 30 2019 8:52 AM
      Hi Ole
      in case this could help
      I retrieve the path using this variable
      Let me know if need more details
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ole Bro
      0 Offline Ole Bro Tue, Jul 30 2019 10:19 AM in reply to Luc Poulin
      Hi Luc,
      It's not there I have the problem. It's when I'm trying to get the absolute file path in the Microstation integration with Projectwise.
      In the selection dialog "Add Binding" I can't find a property containing the absolute file path. Maybe I could create a dummy attribute. Set the value to the system variable you are suggesting and in that way get access to the information I need.
      It's worth testing.
      Thanks for your input.
      Kind regards
      Ole
      ORD Connect:10.08.01.033
      MS Connect: 10.14.02.01
      Projectwise: 10.00.03.49
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Tue, Jul 30 2019 10:47 AM in reply to Ole Bro
      Yes that what I was suggesting
      For other who follow, here few steps
      Under the correct  Environment,
      • I create a new attribute name Full_Path
      • I create a new attribute to trigger the update - UpdateAttr
      In the properties of the Full_Path, under value » Update value section
      configure as my previous post
      Following this set the attribute that will trigger the update value
      Once this done, hit refresh or log-out/in of the admin and then go to the binding ( not sure why sometimes  the new attribute will not show immediate)
      If require add the new attribute so it will be display under attributes or more attributes. ( easier because you can see the value)
      Now from within PW client, select the document » RMB properties.
      change the value of UpdateAttr, this will trigger the Full_Path to be populate
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
