Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Error 32768 - Cannot Login to Datasource
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 10 replies
    • Subscribers 61 subscribers
    • Views 5161 views
    • Users 0 members are here
    • Projectwise Explorer
    • 32768
    • error
    • ProjectWise
    • Windows 10
    Matt Stanley
    Offline Matt Stanley over 4 years ago
    End User is unable to connect to the datasource. I am sure the datasource has been configured correctly, and Prevent UDP has been checked in all appropriate areas.
    We are using ProjectWise V9i and Windows 10 Professional.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Tue, Aug 13 2019 11:18 PM +1 verified
      There is no V9i. If you are running V8i, that isn't supported on Windows 10, upgrade the client to Connect edition. for further debugging you'll need to look at the log file and see what it says. You…
    • Matt Stanley
      0 Offline Matt Stanley Thu, Aug 15 2019 11:25 AM in reply to Kevin van Haaren
      Thank you for that information. Our users here log in with a username and password and I am seeing that the ProjectWise Connect client needs an email account? I don't believe any of our users have ever created am account here. I created one in order to access the downloads but it appears that we need to be subscribed to some cloud service in order to see our projects? Wondering if this is accurate?
      Additionally, my account does NOT have access to the Software Downloads.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Aug 15 2019 4:39 PM in reply to Matt Stanley
      you'll need to talk to your Bentley account manager. The Connection client will be used for licensing all bentley software in the near future, many products already are including the recently released MicroStation V8i SS10.
      Currently to use ProjectWise you do not need to have Connection client installed, but you'll get occasionally get annoying warning about it. The connection client will require an account from Bentley to work.
      Separate from the Connection client Bentley has moved ProjectWise to per user licensing. It depends on your contract but you may already be paying for cloud services as part of your license, to my knowledge getting an account from Bentley does not start this, you'll have to see what's in your contract.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matt Stanley
      0 Offline Matt Stanley Fri, Aug 16 2019 9:42 AM in reply to Kevin van Haaren
      We receive this software from MDOT usually, from a FTP site. At first you're telling me it's a program incompatibility issue, and that I need the Connection Client - now you're telling me it's not explicitly necessary. It seems like other municipalities are using this software on Windows 10. I just need the V8i client working, we don't necessarily NEED cloud services or anything supplemental. I find it difficult to imagine that this program is incompatible with Windows 10, given the instructions make mention of installation on Windows 10. Is there a tech support number available so that I may get this working?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Phil Conard
      0 Offline Phil Conard Fri, Aug 16 2019 11:09 AM in reply to Matt Stanley
      Hi Matt, the last version of PW V8i was published in 2014. Windows 0 was introduced in 2015. The version name changed from V8i to CONNECT in 2015. ProjectWise V8i was never developed to run on the Windows 10 OS, only PW CONNECT Edition. There are many things with the CONNECT brand at Bentley, but for your purposes, you need a PW Explorer version that start with 10.xx. in order to run on Windows 10 OS. My recommendation is to go back to MDOT and ask them for the PW Explorer version that is certified to run on Windows 10.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Aug 16 2019 12:49 PM in reply to Matt Stanley
      I said you need the connect edition of projectwise, not the connection client. The connection client is a separate application from the explorer. It's installed when ProjectWise connect is installed but can be uninstalled separately (go to add/remove programs).
      Bentley's recommended method for opening a support ticket is to go to https://connect.bentley.com login and click New Service Request
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
