Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum How does Plant 3D integration works in ProjectWise v 10.00.03.167?
    • Sign In
    • State Suggested Answer
    • +3 person also asked this people also asked this
    • Replies 4 replies
    • Answers 1 answer
    • Subscribers 64 subscribers
    • Views 2944 views
    • Users 0 members are here
    Vishal Salunkhe
    Offline Vishal Salunkhe over 4 years ago
    Hello All,
    I am trying to make Plant 3D 2019 work with ProjectWise. I recently found that PW connect edition v3.167 has integration module for Plant 3D but I have found no information on how to integrate both.
    Can someone please help me with any documentation or guidelines?
    Vishal
    • Sign in to reply
    • Cancel
    Top Replies
    • Vishal Salunkhe
      Offline Vishal Salunkhe Fri, Nov 5 2021 5:45 AM +3
      I have integrated Plant 3D with ProjectWise in 2 different ways. 1. Using batch file create linked folder with PW working directory. This linked folder will be used for DWGDirectory path variable in ISA_PnIDPart…
    • Phil Conard
      0 Offline Phil Conard Thu, Sep 12 2019 4:57 PM
      The integration that is available for Plant 3D is "basic" integration. This means any of the Plant 3D project specific workflows are not integrated however the same level of integration that is available for base autocad is available for Plant 3D. This included, open, save, xref dialog boxes, titleblock updates, publish, etc. When the vertical specific workflows are integrated, it is called Advanced integration. For example we have Advanced integration for Civil 3D because PWDI can manage that project specific folder and workflows. When it comes to Plant 3D, PWDI does not support database types of files. And because Plant 3D project is primarily database driven, there are no plans for Advanced integration with Plant 3D at  this time.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Ghazi Zien Alabedein
      0 Offline Ghazi Zien Alabedein Tue, Jan 28 2020 4:02 PM in reply to Phil Conard
      is there any new update with PWISE CE update 3.2?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mark Stockall
      0 Offline Mark Stockall Fri, Nov 5 2021 4:44 AM in reply to Phil Conard
      hello Phil,
      has there been any movement / advances in advanced integration for Autodesk plant 3d projects in PWDI.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Vishal Salunkhe
      0 Offline Vishal Salunkhe Fri, Nov 5 2021 5:45 AM
      I have integrated Plant 3D with ProjectWise in 2 different ways. 1. Using batch file create linked folder with PW working directory. This linked folder will be used for DWGDirectory path variable in ISA_PnIDPart.xml file. ISA_PnIDpart.xml file should be moved to the same directory as linked folder. Update project.xml to update the path of ISAPnIDpart.xml file variable. You can archive orignial xml file until this setup works. This process has few drawbacks when it comes to titleblock integration with PW.
      2. Use PW Drive. It creates U:\ for us which is nothing but PW drive storage on your local machine. Every user has this drive. my PW drive will be mapped to local PW drive storage and your U drive will be mapped to your local PW drive storage. basically drive letter/path will remain the same for us. You can create P3D project in this drive using SQL server. Local SQLLite database will not work in this case. Once project is created you can push folder structure to PWE but all the xmls and DCF files need to local (U: drive) for every user. if project settings are changed by one user, others should be notified and provided with these xml files to update their U drive.
      • Cancel
      • Vote Up +3 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
