Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum REFERENCE ATTACH Key-in with Files located on ProjectWise
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 62 subscribers
    • Views 1220 views
    • Users 0 members are here
    • MicroStation
    • ProjectWise
    • KEY-IN
    Jovan Djukanovic
    Offline Jovan Djukanovic over 3 years ago
    Can I use a keyin to attach files located on ProjectWise?
    From help;
    REFERENCE ATTACH (or RF=)[configuration_variable:]<file_name>[,model_name][,logical_name][,description][,view_name][,scale][,nesting][,on|off]
    I use this keyin regularly for files on a network. I tried to use the PW path such as in the example below;
    REFERENCE ATTACH "pw:\\wsp-aus-pw.bentley.com:company-aus-pw-17\Documents\Project\File.dgn",Default,,,,,
    ...but it doesn't work.
    Ultimately this is to be used in a batch process over 300 odd files.
    • Sign in to reply
    • Cancel
    Top Replies
    • Jaimin Patel
      Offline Jaimin Patel Wed, Aug 3 2022 12:15 AM +1
      Hi Jovan, You can use PW DMS location and it will work. Example, rf=C:\Temp\d0102502\STP-501-C-SPA-M2D-16-GRN-CSW-0222.dgn,default,,,,,, In the example "C:\Temp" is set as my Projectwise…
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Oct 30 2019 4:29 PM
      I know this works as I've got users doing it in batch processes. When I tested on my system it worked if I didn't put in the model name. If I put in the model name it would say it couldn't find model D in the file (always the first letter of whatever i put in, never the whole string).
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Jaimin Patel
      0 Offline Jaimin Patel Wed, Aug 3 2022 12:15 AM
      Hi Jovan,
      Example,
      In the example "C:\Temp" is set as my Projectwise working directory
      d0102502 is the dms folder name
      Hope this helps.
      Jaimin Patel
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • KAMRAN AHMED
      0 Offline KAMRAN AHMED Wed, Jan 18 2023 1:46 AM in reply to Jaimin Patel
      Please provide key-in how to attached multiple design file within a same folder
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
