Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Excel 2016 opening to Excel Home
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 6 replies
    • Subscribers 62 subscribers
    • Views 1863 views
    • Users 0 members are here
    Ranveer Basra
    Offline Ranveer Basra over 3 years ago
    Hi
    ProjectWise 10.00.03.167
    Windows 10 OS
    Office365 with latest 11/22 update
    Has anyone encountered opening a Excel file from ProjectWise and it launches Excel however takes to you the Home location (Screenshot below)?
    If you click on blank document it opens a blank document and the file that was launched from ProjectWise.
    • No user association set... global user association for excel integration works for most and not for others.
    • Integration is enable.
    • We do not want to force opening worksheet since the check in dialog does not show after closing the file.
    went through the steps in this link below however after deleting the curver it takes me to the worksheet and no check in dialog is presented. I ran a repair and back to the state of opening to the home location of Excel: https://communities.bentley.com/products/projectwise/content_management/w/wiki/7780/blank-word-document-or-excel-sheet-opens-with-projectwise-office-integration
    ///R
    • Sign in to reply
    • Cancel
    Top Replies
    • Mark Shamoun
      Mark Shamoun Fri, Dec 6 2019 5:54 AM +3 verified
      Hi, We've changed our application command line options for excel to include the "/e" switch that disables the startup screen I put an SR in for this and was told it was due to a change in Excel…
    • Joe Rodriguez
      Offline Joe Rodriguez Thu, Feb 6 2020 11:34 AM in reply to Leah Mize +2 verified
      The command line is added in Projectwise Administrator > Applications > Microsoft Excel. Double click it and go to actions tab then modify the Open action and in Command Line arguments add the /e and click…
    • Peter Willmen
      0 Offline Peter Willmen Fri, Nov 29 2019 3:30 AM
      I have this same issue after a forced removal and re-install of ProjectWise Explorer. The functionality was fully working prior to this.
      Various attempts to fix the issue - remove/re-install, Repair, Registry changes as above  - have not resolved it.
      I have not yet had a chance to log a SR though
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Alex Acton
      0 Offline Alex Acton Wed, Dec 4 2019 9:49 PM
      I've been getting around this by telling users to switch off the Start screen option in Excel itself.
      In Excel - File -> Options and scroll down to the bottom 'Start up Options'
      Disable 'Show the start up screen when this application starts'
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mark Shamoun
      +1 Mark Shamoun Fri, Dec 6 2019 5:54 AM
      I put an SR in for this and was told it was due to a change in Excel code?
      Mark
      OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023  |  ProjectWise CE 3.4
      Answer Verified By: Vickie Ramsey
      • Cancel
      • Vote Up +3 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Leah Mize
      0 Offline Leah Mize Thu, Feb 6 2020 10:54 AM in reply to Mark Shamoun
      Where do we add this command line?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Joe Rodriguez
      +1 Offline Joe Rodriguez Thu, Feb 6 2020 11:34 AM in reply to Leah Mize
      The command line is added in Projectwise Administrator > Applications > Microsoft Excel. Double click it and go to actions tab then modify the Open action and in Command Line arguments add the /e and click ok.
      Mark, thanks for posting this.
      Answer Verified By: Ranveer Basra
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
