Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum C3D how to prevent connection to DS project
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 321 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin over 3 years ago
    Hello all
    Ran into an issue where  I need to force a C3D file to NOT connect to a DS project and force that window to popup
    So user can click NO
    Anyone has a trick to force this window to popup?
    Thank you for any tips or trick
    • Sign in to reply
    • Cancel
    • Dave Cumming
      0 Offline Dave Cumming Sat, Dec 3 2022 11:35 AM
      Hi Luc,
      There is no way to force this warning to pop up if the reference path to the data shortcut project is valid and Civil 3D resolves it when the drawing file is opened.
      That warning pops up when a .dwg file has been explicitly associated with a .CivilDSProj file (a Data Shortcut Project) that cannot be found in ProjectWise.
      You can remove the association in the .dwg file, but then the warning will not pop up.
      In versions of Civil 3D prior to 2022.2, if a .dwg file had no association with a DSP, Civil 3D would remain set to the last used DSP. In C3D 2022.2 there is a system variable to defeat that behavior.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
