Hello Community,
how can i hide the version of referenced files in the "Referenced By" window? "Right click on a file > Set > Referenced By". I only need to view the current active versions of the referenced documents like you can set it in the normal Explorer Client view.
Thanks for your help!
Using ProjectWise 10.00.03.262
Could you please try to remove the "Show all Version" setting from user settings!
~Amol
Yeah tried this but it does not work at all. Its a bug which Bentley already approved.
Hello Christian,
There is a defect already raised. Defect Number :1066567 for this issue.
There is no option t filter the listed files in a location such as referenced files in a location. Is there a reason why you would not want to see all of the files in a location?
when it lists all versions it can be difficult to tell which is the master version, and even then, if you have a lot of versions the list is very unwieldy to scroll through. If the file you're attaching is in a read-only folder you can't just scan the icon as they're all tagged read-only then.
If you never attach old versions, why display them? For us, we never need to attach versions.
This is something that shouldn't even be controlled by User Settings but by a view option with a button on the tool bar to toggle on and off. when we need versions it's typically for a short period of time. Changing user options is a lot of steps for that. (also files that are versions should have a different icon than just the read-only icon so they are more quickly identified)
