I am new to Microstation CE and trying to understand how worksets are intended to be used. The sheet index is something that all users need to access from wherever they are (different offices, etc). The sheet index is stored in the workset file which is stored locally to my knowledge. So my questions are:
Thanks in advance!
It is my understanding that all of the references and settings that are included in a drawing are linked within ProjectWise and brought out to a local working directory when you open a drawing from within Projectwise. This means that when you copy out or open, all necessary files will be brought to your local working directory under a DMS folder.
