Where is the Revit 2020 integration module is it apart of the 3.271 build? it sounded like from a different post it was going to be released later after ProjectWise 3.2 was released?
I did not see it on the downloads site either.
Thanks in Advance
found it:
Maybe this will help other's looking for this. It is on the old fulfillment center site. Odd half the stuff is listed on the old site and other half on the new site....
As of 271, it is a separate module. I believe it will bundled with 3.3 versions.
Answer Verified By: Ranveer Basra
I'm having problems while opening Revit files from ProjectWise afetr opening the file it closed direct back in with the popup to free or check in the file? Any help I would preciate.
ProjectWise Client: 10.00.03.280
Revit 2020.2
Have you filed a service request and gotten product support on your issue Christiaan?
