<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>AutoCAD 2020 Integration Install Fails</title><link>https://communities.bentley.com/products/projectwise/f/projectwise-di-forum/195943/autocad-2020-integration-install-fails</link><description>When trying to install the ProjectWise Integration for Autodesk AutoCAD 2020 we receive the error:
 ProjectWise Explorer CONNECT Edition Update 3.2 or later is required to install ProjectWise Integration for Autodesk AutoCAD 2020.
 We currently have</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: AutoCAD 2020 Integration Install Fails</title><link>https://communities.bentley.com/thread/585419?ContentTypeID=1</link><pubDate>Fri, 08 May 2020 10:17:01 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:35e23ecc-cbaf-4766-b619-1156d6a173c7</guid><dc:creator>Mantas Bagusas</dc:creator><description>&lt;p&gt;Hello Christopher,&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Have you downloaded integration AutoCAD 2020 version 10.00.03.541 from &amp;nbsp;&lt;a href="https://softwaredownloads.bentley.com/en/ProductDetails/2546"&gt;https://softwaredownloads.bentley.com/en/ProductDetails/2546&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;Example how to select for correct version to download, more details can be seen when you press icon &amp;quot;i&amp;quot;:&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="/resized-image/__size/640x480/__key/communityserver-discussions-components-files/342986/6765.Example1.JPG" /&gt;&lt;/p&gt;
&lt;p&gt;Also installation order should be (&amp;nbsp;Your required software&amp;nbsp;+ Project Wise Explorer + Integration Module)&lt;/p&gt;
&lt;p&gt;Let me know if it helped.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Mantas B.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
