Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Creating a new project in Projectwise with standard folders?
    • Sign In
    • State Verified Answer
    • Replies 1 reply
    • Subscribers 61 subscribers
    • Views 562 views
    • Users 0 members are here
    peberhart
    Offline peberhart over 3 years ago
    This might be a simple question but I can't seem to find the solution. All I want to do is create a new project and have the same set of folders, subfolders and dgn files in every project. A template. Can Projectwise do this?
    Thanks.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, Apr 30 2020 9:28 PM +1 verified
      Yes. You'll need an area in ProjectWise designated to hold your templates. Create that area and create a sub-folder with the Template name. Under that create your folders, subfolders and dgn files (scan…
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Thu, Apr 30 2020 9:28 PM
      Yes. You'll need an area in ProjectWise designated to hold your templates. Create that area and create a sub-folder with the Template name. Under that create your folders, subfolders and dgn files (scan ref the dgn files in the template if they have reference files, when the template is copied references will be updated to the new project).
      Your projectwise administrator (if that's not you) will then designate that Template area in the ProjectWise administrator datasource settings. Documentation here:
      https://docs.bentley.com/LiveContent/web/ProjectWise%20Administrator%20Help-v9/en/GUID-8295E6CB-8C60-0C95-4648-05E84C6D8A67.html
      Once that's done when you create a new work area using the Work Area Creation Wizard you can pick the template. Instructions on the creation wizard are here:
      https://docs.bentley.com/LiveContent/web/ProjectWise%20Explorer%20Help-v9/en/GUID-6B6B7FCD-983F-43A7-6BF2-4426C1CAA7EC.html
      (edit to fix grammar and spelling errors)
      Answer Verified By: peberhart
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
