Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Adding versions to files
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 61 subscribers
    • Views 400 views
    • Users 0 members are here
    Tony Cacciola
    Offline Tony Cacciola over 3 years ago
    When we first drag and drop a whole bunch of files in Projectwise we would like to add a version in the properties of the files.
    My question:
    Is there  a way to be able to add a version description to all the files at once instead of adding them one by one in the properties dialog box ?
    Thank you
    • Sign in to reply
    • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Wed, May 13 2020 12:46 PM
      Hello Tony ;-)
      After  you have import all your documents, select the all =» RMB and select modify =» enter the desire value
      This will apply the same value to all the files being selected, the version field is not available for this
      For version, select all the documents =» RMB and select new =» Version. A new version will be create and all will have the same value. Previous version will not be affected but will be in read only.
      At the  import time, do not believe we can do this...... maybe someone else have a trick
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
