Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum dms_delete
    • Sign In
    • State Not Answered
    • Replies 14 replies
    • Subscribers 63 subscribers
    • Views 1907 views
    • Users 0 members are here
    dms_delete
    Luc Poulin
    Offline Luc Poulin over 3 years ago
    Hello
    Anyone has a detail explanation of when PW will add prefix like
    dms_delete
    dms_missref
    etc...
    Trying to reproduce the scenario that lead to this
    • Sign in to reply
    • Cancel
    Top Replies
    • Loris Paoletich
      Offline Loris Paoletich Thu, Jul 7 2022 9:40 PM in reply to Gayatri Belhekar +2
      Hi Gayatri, We are having issues with data shortcuts not finding the source dwg. None of the source dwg have been removed from PW, but for whatever reason all the reference files they now have the dms_deleted…
    • Luc Poulin
      0 Offline Luc Poulin Thu, Jul 9 2020 8:07 AM in reply to Gayatri Belhekar
      PWDI. I believe, refer to server host by bentley we do not .
      On premise integration is .140
      client is .262
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gayatri Belhekar
      0 Offline Gayatri Belhekar Thu, Jul 16 2020 6:57 AM in reply to Luc Poulin
      Hi Luc, dms_deleted is used to save the deleted items from that folder.
      If source DWG is removed from PW, the datashortcut in the project points to ‘dms_deleted’ prefixed filename, but the datashortcut in the XML is not removed from the project. So the shortcut will be not found in the file.
      Local file system references are ignored. ProjectWise references are ignored or denied to load if the file exists locally but removed from ProjectWise. Data references that point to removed ProjectWise documents will be re-pathed to a non-existing document(‘dms_deleted’ added to the path), to avoid loading in the future. Hope this helps.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Loris Paoletich
      0 Offline Loris Paoletich Thu, Jul 7 2022 9:40 PM in reply to Gayatri Belhekar
      Hi Gayatri,
      We are having issues with data shortcuts not finding the source dwg. None of the source dwg have been removed from PW, but for whatever reason all the reference files they now have the dms_deleted prefix. Is there a way to fix this? I tried to repair shortcuts in several ways, but they keep breaking and not finding the source files. Thanks.
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dave Cumming
      0 Offline Dave Cumming Thu, Jul 21 2022 6:20 PM in reply to Loris Paoletich
      Hi Loris,
      Has the location of your Local Working Directory changed?
      You may need to purge your Local Working Directory with the ProjectWise Local Document Organizer, and then go to Windows and delete all of the the folders that begin with a "d" or a "dms" prefix.
      In order to investigate the cause, compare the folder location where the (host) drawing is looking for references to the ProjectWise folder (Folder ID) where those drawings are currently located. Take a few screenshots of the "before" conditions while you have one of a host drawing open, and then close that file.
      (FYI: You may need to create a personal view and add the Folder ID column to it in order to see that data.)
      Prior to opening a host drawing that presents this dms_deleted condition, try navigating in ProjectWise to the file(s) that it is referencing and selecting Copy Out on the reference file(s) in order to make sure that they exist in your Local Working Directory. Then open the host drawing and see if it is still presenting you with the dms_deleted condition. If it is, compare the folder number where it is looking for the reference(s) to the folder ID that you Copied Out the reference file(s) from.
      (BTW, If this issue is related to your XREFs and you are not getting the "missing XREF" dialog box when you open the file, asking you to ignore, repath or delete the reference, you probably have the system variable turned off. DMSSET > REFMISSINGMODE) See: DMSSET Variables for Integrated AutoCAD (bentley.com)
      If this is related to Data Shortcuts, try using the Manage Data Shortcuts tool to repair the broken DREFs.
      Be sure to Synchronize References after the repairs are complete.
      Save; Close; Check In; and re-open the file. You may need to repair and synchronize some of the Data Shortcuts again before it sticks.
      If you are seeing dms_deleted in the paths of the data shortcuts (not the data references) then you need to repair those before you are able to repair the broken DREFs.
      If you look at the .CivilDSProj file with the ProjectWise Data Shortcut Project Editor, you will see that the locations of the Data Shortcuts' Source Drawings need to be defined.
      Defining the locations with that application is much more efficient that doing it from the Civil 3D interface, but you should make sure that all of the source drawings are checked in before you check out the .CivilDSProj file.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Bradley Armstrong
      0 Offline Bradley Armstrong Fri, Aug 26 2022 12:12 PM in reply to Dave Cumming
      I'm running into the same problem as Loris this week. Following your suggestion, am I supposed to delete all of the "d" or "dms" folders associated with only the affected project or all on my local working directory?
      I have hundreds of other files associated with other active projects not experiencing this issue and would prefer not to have to replace all that information again.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
