Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum References to projectwise
    • Sign In
    • State Verified Answer
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 509 views
    • Users 0 members are here
    • CONNECT Edition
    • MicroStation
    • ProjectWise
    • v10
    Anastasiya Zaytseva
    Offline Anastasiya Zaytseva over 3 years ago
    Hello! When working with Microstation it often happens that when using the "References" button it is impossible to find the path to ProjectWise if my project was created on the hard drive.
    On other computers, you can find files from ProjectWise.
    • Sign in to reply
    • Cancel
    Top Replies
    • Andzej Prokopovic
      Offline Andzej Prokopovic Wed, Jul 15 2020 5:01 AM +1 verified
      Hello Anastasiya, When you work on a file in MicroStation which was opened not from ProjectWise but from your local drive then you are working not in the integrated mode thus you cannot access the references…
    • Andzej Prokopovic
      +1 Offline Andzej Prokopovic Wed, Jul 15 2020 5:01 AM
      Hello Anastasiya,
      When you work on a file in MicroStation which was opened not from ProjectWise but from your local drive then you are working not in the integrated mode thus you cannot access the references that are located in ProjectWise. The project that is saved on a local hard drive should be moved to the ProjectWise in order to be able to attach references from the ProjectWise.
      Andzej
      Answer Verified By: Anastasiya Zaytseva
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
