Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise Audit Trail Action Name
    • Sign In
    • Replies 7 replies
    • Subscribers 62 subscribers
    • Views 9670 views
    • Users 0 members are here
    • ProjectWise
    Ben Fullenkamp
    Ben Fullenkamp over 14 years ago
    I am creating some reports in Access based off the dms_audt table for Projectwise and while it references action code in the table, it doesn't have any obvious link to another table where it actually pulls the "Checked Out" or "Exported" etc... text and it doesn;t seem to follow a logical pattern as to what code relates to what action.  Where does the text for the action name come from and how can I link it to my query so I can show what action the users in the reports are doing?
    • Sign in to reply
    • Cancel
    • John Schown
      Offline John Schown Fri, Mar 20 2009 7:51 PM
      The Action Names are in code vs another table in the database.  The reason for this is so that they can be translated for the various languages that ProjectWise supports.
      Let me see if I can get a list of action names to IDs.
      HTH,
      John
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • John Schown
      Offline John Schown Mon, Mar 23 2009 8:26 PM in reply to John Schown
      Give this a try:
      1001 - Document created.
      1002 - Document's general properties modified.
      1003 - Document attributes modified.
      1004 - Document file added.
      1005 - Document file removed.
      1006 - Document file replaced.
      1007 - Document checked-in.
      1008 - Document viewed.
      1009 - Document checked-out.
      1010 - Document copied-out.
      1011 - Document given-out.
      1012 - Document state changed.
      1013 - Document final status set.
      1014 - Document final status removed.
      1015 - New document version created.
      1016 - Document moved.
      1017 - Document copied.
      1018 - Document permissions changed.
      1019 - Redline created or accessed.
      1020 - Document deleted.
      1021 - Document exported.
      1022 - Document freed.
      1023 - Document extracted.
      1024 - Document distributed.
      1025 - Document was sent.
      1026 - Commented by user.
      1027 - Document imported.
      2001 - Document set formed.
      2002 - Document set member added.
      2003 - Document set member removed.
      1 - Project/folder created.
      2 - Project/folder modified.
      3 - Project/folder workflow changed.
      4 - Project/folder deleted.
      5 - Project/folder state changed.
      • Cancel
      • Sign in to reply
      • Cancel
    • Ben Fullenkamp
      Ben Fullenkamp Tue, Mar 24 2009 1:13 PM in reply to John Schown
      That worked great.  I just created my own table with these values and it seems to correspond perfectly.  Thanks for your help.
      • Cancel
      • Sign in to reply
      • Cancel
    • Jon Evans
      Offline Jon Evans Fri, Mar 27 2009 3:16 PM
      For reports I ended up doing this is what I came up with.
      If you would happen to figure out anymore let me know.
      Report Info, o_action column in the dms_audt Table
      1001 is Created
      1002 is Modified
      1004 is File Added/Renamed
      1007 is Checked In
      1008 is Viewed
      1009 is Checked Out
      1010 is Copied Out
      1011 is Copied To File
      1013 is Final Status Set
      1014 is Final Status Removed
      1016 is Moved
      1017 is Copied From File
      1021 is Exported
      1022 is Freed
      1023 is DS Extracted
      1024 is DS Distributed
      1025 is Sent to Email Recipient
      2001 is Set Formed
      2002 is Member Added
      2003 is Member Removed
      • Cancel
      • Sign in to reply
      • Cancel
    • Kevin
      Offline Kevin Fri, May 27 2016 1:55 AM in reply to Jon Evans
      I need the same code listing for object type 6 ... please ... getting 3 thousand type codes ... 3001 ,3002
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
