Hi there,
i was wanting to change the name and file name of drawings using the export/import tool, but i cant seem to get it working. Other attributes are updated but not file name and name. is there a tick box or something i'm missing during the import process?
I dont want to add a prefix or suffix, but change some numbers due to scope change.
any help appreciated.
Trent
Hi Trent,
Can you please raise a Service request for this
Ayaz
Have you considered PowerShell for this? If not, have have a look at https://communities.bentley.com/products/projectwise/content_management/f/projectwise-powershell-extensions-forum and check out PWPS_DAB, and look at the the Rename-PWDocuments cmdlet.
Seems like it would do what you need without having to take files through an export/import process.
Please note that I post here on a voluntary basis and am not a Bentley employee.
