Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum CMMC Requirements
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 2 replies
    • Subscribers 61 subscribers
    • Views 1023 views
    • Users 0 members are here
    • v8i
    • NIST
    • ProjectWise
    • CMMC
    CMMC Requirements
    David Ross
    Offline David Ross over 2 years ago
    I am trying to make Projectwise V8i meet the security requirements called out in CMMC (the update to 800-171).
    Can it be configured to require MFA (multifactor authentication)?
    Are the files stored on the host server encrypted to a level acceptable to FIPS 140-2?
    Lastly, as the files are being uploaded & downloaded, are they encrypted?
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Online Kevin van Haaren Fri, Nov 20 2020 2:23 PM in reply to Amol +1 verified
      If they're using ProjectWise V8i I assume they aren't using hosted Projectwise. On premise Projectwise is NOT encrypted on the server store unless it has been added by admins, ProjectWise does not encrypt…
    • Amol
      0 Offline Amol Fri, Nov 20 2020 4:55 AM
      It is possible to configure the multifactor authentication, I have seen user doing with CONNECT Version however not sure about the V8i.
      Filestore on the hosted is encrypted not sure about the protocol. We need to check this with Managed services.
      Yes, it is encrypted.
      Let me know if you have any other questions.
      This is a test
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      +1 Online Kevin van Haaren Fri, Nov 20 2020 2:23 PM in reply to Amol
      If they're using ProjectWise V8i I assume they aren't using hosted Projectwise. On premise Projectwise is NOT encrypted on the server store unless it has been added by admins, ProjectWise does not encrypt on storage by default. Also file transfers are NOT encrypted unless this has been setup by the admins, it also is not the default.
      I believe multi factor authentication only works with CONNECTION client logins, which requires CONNECT servers.
      Answer Verified By: Amol
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
