Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum PW Web View direct access to subfolder
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 61 subscribers
    • Views 1347 views
    • Users 0 members are here
    Rene Lloyd
    Offline Rene Lloyd over 2 years ago
    I want to give an external user a link to direct access to a subfolder in ProjectWise Web View, and to not give access to the folder tree above it.
    This was possible in the old Web Server, but seems not to be allowed in PW Web View. The link fails and sends you back to the top level where nothing is visible because the user has no rights there.
    Can anyone confirm that this is how it is supposed to work, so that I can't use Web View for this, and I would need to publish the subfolder as a project in PW Web ?
    • Sign in to reply
    • Cancel
    Top Replies
    • Rene Lloyd
      Offline Rene Lloyd Mon, Oct 12 2020 9:11 AM in reply to Sean Duphily +1 verified
      Yes, I can access the folder if I make a link to a file inside the folder, but not if I make a link to the folder,which obviously requires access to the level above it. Thank you :)
    • Ayaz Khan
      0 Offline Ayaz Khan Mon, Oct 12 2020 8:30 AM
      Hi Rene,
      As far as i know i think yes this is how it supposed to work .
      Mary Kay Sheahan  Could you please confirm if this correct ?
      Ayaz
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Sean Duphily
      0 Offline Sean Duphily Mon, Oct 12 2020 8:50 AM
      It looks like there needs to be a way to link your current location in the directory tree rather than only an object you can select.
      Although, I just tested copying the address of a location and using that instead and it works fine.  No need to have access at the parent folder.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Rene Lloyd
      +1 Offline Rene Lloyd Mon, Oct 12 2020 9:11 AM in reply to Sean Duphily
      Thank you :)
      Answer Verified By: Rene Lloyd
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Sean Duphily
      0 Offline Sean Duphily Mon, Oct 12 2020 9:39 AM in reply to Rene Lloyd
      Well, you don't need to link to a file inside the folder.  You just need to navigate to the folder and then copy the full path in the address bar.  What's screwy is that this same operation is not achievable that I can see within the PW client.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mary Kay Sheahan
      0 Offline Mary Kay Sheahan Tue, Nov 24 2020 11:48 AM in reply to Rene Lloyd
      Rene,  Can try this again? I am able to copy the folder link and send to someone who can open to the correct folder location. We pushed some bug fixes, so I'm interested if this works for you now.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
