ProjectWise Explorer Advanced Document Creation Wizard recent used template max number
The max seems to be 10 recent used templates when using the ADC Wizard.
Does anyone know if this is a value that can be changed?
Given the path folder has 3 numbers you would assume the ability to at least be somewhere in the 10+ range.
HKEY_CURRENT_USER\Software\Bentley\ProjectWise Explorer\DCW\kbr-au-pw.bentley.com:kbr-au-pw-01_staging\LastUsedDocList\009
Creating a new Custom Wizard with the api might be the only way past that limitation.
