Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise - Data back up/Archive/Protection
    • Sign In
    • State Verified Answer
    • Replies 5 replies
    • Subscribers 63 subscribers
    • Views 1272 views
    • Users 0 members are here
    • Projectwise Explorer
    • ProjectWise
    • Project Wise
    S. R.
    Offline S. R. over 2 years ago
    A few questions regarding Projectwise and Data Protection:
    Can folders, projects, and/or files be archived? If it is archived, is there ways to 'unarchive' the folders and bring the projects back?
    How is Projectwise Data backed up? And if there is an incident, how can data be recovered?
    • Sign in to reply
    • Cancel
    Top Replies
    • Gayatri Belhekar
      Offline Gayatri Belhekar Fri, Nov 6 2020 5:07 AM +2 verified
      Currently, there is no option to archive and unarchive the projects in ProjectWise Explorer. You can use access control to temporarily remove access from the users for those projects or just give read…
    • Kevin van Haaren
      Offline Kevin van Haaren Sun, Nov 8 2020 9:51 PM in reply to S. R. +1
      If you're familiar with Powershell you might review this post on using the Projectwise powershell tools to archive projects. powerwisescripting.blog/.../
    • Gayatri Belhekar
      +1 Offline Gayatri Belhekar Fri, Nov 6 2020 5:07 AM
      Currently, there is no option to archive and unarchive the projects in ProjectWise Explorer. You can use access control to temporarily remove access from the users for those projects or just give read access to those projects, but the project will still be visible in the system.
      For database maintenance, please refer to this link - https://communities.bentley.com/products/projectwise/content_management/b/weblog/posts/database-maintenance-for-projectwise
      If your datasource is hosted by Bentley, database maintenance is done by Bentley for you.
      Answer Verified By: S. R.
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • S. R.
      0 Offline S. R. Fri, Nov 6 2020 8:56 AM in reply to Gayatri Belhekar
      Awesome, thank you!
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Sun, Nov 8 2020 9:51 PM in reply to S. R.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gayatri Belhekar
      0 Offline Gayatri Belhekar Tue, Nov 10 2020 5:54 AM in reply to Kevin van Haaren
      I concur, PowerShell can be used to export and archive projects on a local drive. If you have any questions about PowerShell scripting, you can post on the below forum:
      https://communities.bentley.com/products/projectwise/content_management/f/projectwise-powershell-extensions-forum
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Bill Graefe
      0 Offline Bill Graefe Thu, Nov 12 2020 4:40 PM in reply to Gayatri Belhekar
      I recommend keeping like with like. If  you want to be able to unarchive over a shorter term, I agree with security changes. Later, I would use powershell to move to another datasource for archives that has the same configurations as the source. There's always the chance of an "unarchive" of any kind except security changes to go wonky. Security changes could involve using poweshell to export the current security starting at the topmost level and saving it inside the top folder/work area then change it (possibly by moving it to an Archive folder). A separate datasource performs better in the long run.
      ProjectWise is a system of database(s) and file storage in windows (SAN). You would back those up.
      Bill
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
