Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum External users consuming licenses
    • Sign In
    • State Suggested Answer
    • +2 person also asked this people also asked this
    • Replies 8 replies
    • Answers 2 answers
    • Subscribers 63 subscribers
    • Views 2452 views
    • Users 0 members are here
    • License
    • User Management
    stwil
    Offline stwil over 2 years ago
    It appears when external users from other organizations are working in our hosted projectwise environment, they are consuming product licenses from our tenant even though they have their own licenses through their own tenant. Is there a way to prevent them from consuming these licenses from our tenant?
    Thanks for your help,
    Stephen
    • Sign in to reply
    • Cancel
    Top Replies
    • Gokul Sasidharan
      Offline Gokul Sasidharan Sat, Dec 12 2020 1:05 PM +3 suggested
      Hi Stephen, Thanks for contacting Bentley Systems! If ProjectWise Explorer for the external users are activated with their own SELECT Server Site Activation key, it is required to just change the User…
    • Gokul Sasidharan
      Offline Gokul Sasidharan Fri, Jan 15 2021 9:17 AM in reply to Sean Duphily +1 suggested
      Hi Sean, Please be informed that there has been a new SES licensing system introduced to ProjectWise replacing the legacy SELECT Server Licensing. Please refer below documentation for more information…
    • Gokul Sasidharan
      +1 Offline Gokul Sasidharan Sat, Dec 12 2020 1:05 PM
      Hi Stephen,
      Thanks for contacting Bentley Systems! If ProjectWise Explorer for the external users are activated with their own SELECT Server Site Activation key, it is required to just change the User's profile settings on that datasource from ProjectWise Administrator to select the option to "Activate and record usage through client's configured SELECT Server". Please find below documentation explaining the steps -
      https://docs.bentley.com/LiveContent/web/ProjectWise%20Administrator%20Help-v9/en/GUID-6BDBACFD-B490-882C-49E6-07C6C2A6E473.html
      Thank you.
      • Cancel
      • Vote Up +3 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Sean Duphily
      0 Offline Sean Duphily Wed, Jan 13 2021 3:52 PM in reply to Gokul Sasidharan
      Gokul,
      As of version 10.00.03.434, that option is gone.
      Older version dialog:
      Current version (10.00.03.434) dialog:
      Thank you.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mark Shamoun
      0 Mark Shamoun Fri, Jan 15 2021 8:43 AM in reply to Sean Duphily
      The "old" version is also in the current help - was this section removed in PW Admin removed intentionally?
      Mark
      OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023  |  ProjectWise CE 3.4
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gokul Sasidharan
      0 Offline Gokul Sasidharan Fri, Jan 15 2021 9:17 AM in reply to Sean Duphily
      Hi Sean,
      Please be informed that there has been a new SES licensing system introduced to ProjectWise replacing the legacy SELECT Server Licensing. Please refer below documentation for more information about the same-
      https://communities.bentley.com/products/projectwise/content_management/b/weblog/posts/introduction-to-ses-for-projectwise-design-integration
      Thank you
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Jan 15 2021 11:24 AM in reply to Mark Shamoun
      Yeah, basically for SES licensing you handle this differently so they pulled the checkboxes from the admin interface. If you have an older Projectwise I wouldn't use 434 Admin to administer it.
      you can also set this setting with powershell as a workaround if you really need the 434 Admin.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
