Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum WorkSpace Copies filter lists all copied out design documents, while Copies filter remains empty
    • Sign In
    • State Not Answered
    • Replies 7 replies
    • Subscribers 60 subscribers
    • Views 1246 views
    • Users 0 members are here
    • Projectwise Explorer
    • MicroStation
    • ProjectWise
    • Local Document Organizer
    TSAlex
    Offline TSAlex over 2 years ago
    ProjectWise Explorer, v. 10.00.02.99I
    IntegratedPower Geopak V8i (SELECT series 10), v. 08.11.09.918
    Managed Workspace environment
    The "WorkSpace Copies" filter in the Local Document Organizer is listing all local design files & references copied out during normal master file Check Out, as well as all workspace resource files. The separate filter list for "Copies" in LDO is practically empty (except for one file: world.dpr). This behavior appears to defeat the purpose of having these filters at all, which seem aimed at making it easier to parse local files to manually purge in the event of workspace file deletions in the Datasource, or otherwise manage copied out design documents separately.
    It seems reasonable that the lack of differentiation by ProjectWise between WorkSpace resource files and copied out design documents might also be causing other problems by packaging design files in with managed workspace exports.
    In any case, what I'm observing does not appear to be working as intended, and I am concerned that the excessive 'copy out' and 'managed workspace export' operations we are experiencing during ordinary plans production are being caused by this apparent incorrect classification of document 'Copies' vs. 'WorkSpace Copies' in PW.
    Is it possible that the Managed Workspace configuration variables for this particular project are too broadly defined, and end up flagging every resolved directory and its contents as 'WorkSpace' files? If so, what are some workarounds - if not, what explains this filter behavior in LDO?
    TS
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Nov 20 2020 5:48 PM +1
      are you specifying a MS_RFDIR or MS_DEF in your workspace? When files appear in the workspace tab it's because Projectwise thinks the file, or the directory the file is in, is part of the workspace.…
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Nov 20 2020 7:14 PM in reply to TSAlex +1
      Neither should be defined in a managed workspace referring to folders inside of Projectwise. If MS_RFDIR is defined it should only point to folders outside of ProjectWise that hold reference files (although…
    • Kevin van Haaren
      Offline Kevin van Haaren Sun, Nov 22 2020 11:17 AM in reply to TSAlex +1
      After setting the variables did you purge the workspace files and try again? Three ideas: 1. managed workspaces are processed twice, once by Projectwise and once by microstation. Projectwise processes…
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Nov 20 2020 5:48 PM
      When files appear in the workspace tab it's because Projectwise thinks the file, or the directory the file is in, is part of the workspace. You can bring up the workspace dialog and see what variables refer to those directories.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • TSAlex
      0 Offline TSAlex Fri, Nov 20 2020 6:25 PM in reply to Kevin van Haaren
      I don't have admin access, but the MS_RFDIR and MS_DEF both appear to be defined in the managed workspace (according to the .pcf file).
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Nov 20 2020 7:14 PM in reply to TSAlex
      If MS_RFDIR is defined it should only point to folders outside of ProjectWise that hold reference files (although this is generally a bad idea). ProjectWise handles reference pathing for files inside of ProjectWise.
      MS_DEF shouldn't be defined at all.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • TSAlex
      0 Offline TSAlex Fri, Nov 20 2020 7:18 PM in reply to Kevin van Haaren
      Great, thank you Kevin. Are MS_DEF & MS_RFDIR the only two problem variables I should be looking to disable in the managed workspace?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Nov 20 2020 8:51 PM in reply to TSAlex
      Off the top of my head, yes. Might be some rarely used ones that I'm forgett About.
      btw, it's best to avoid MS_RFDIR in any Projectwise workspace - managed or not.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
