Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum FREE option disabled on ProjectWise Web
    • Sign In
    • State Suggested Answer
    • Replies 11 replies
    • Answers 2 answers
    • Subscribers 61 subscribers
    • Views 1814 views
    • Users 0 members are here
    Aitor de la Fuente
    Offline Aitor de la Fuente over 2 years ago
    Since we have started using ProjectWise Web, the option to Free a document when a Check Out has been performed is not available to any user, with the exception of administrator accounts.
    The option appears to everyone but cannot use it. All users can and could free their checked out documents in ProjectWise Explorer, in that sense the configuration from ProjectWise Administrator is correct.
    How can we solve this aspect?
    Best regards,
    • Sign in to reply
    • Cancel
    Top Replies
    • Jacob Gearhart
      Offline Jacob Gearhart Mon, Dec 7 2020 2:49 PM in reply to Aitor de la Fuente +2 suggested
      Hi Aitor, I did some investigation and it looks like we have a bug with this feature when using servers using PW WSG Plugin version 3.2 or lower which is what your WSG is using. I am working on a fix…
    • Chris Andrew
      0 Offline Chris Andrew Sat, Dec 5 2020 1:39 PM
      Projectwise Web complies with ProjectWise Explorer Access Control.
      Do you have any specific Workflow or Folder Access Control setup that is restricting users ability to free
      Chris
      AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
      Associate Director – Digital
      OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
      Civil 3D 2023 | Dynamo | Navisworks Manage
      PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
      Speckle | BIMVision | Revizto | Solibri
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Aitor de la Fuente
      0 Offline Aitor de la Fuente Mon, Dec 7 2020 2:43 AM in reply to Chris Andrew
      Thanks for your reply Chris.
      We've been working with ProjectWise Explorer for five years and never had this problem. The same users who can free the documents they have checked out from Explorer, do not have this option available when they enter the same work area, same folders, in the Web version and check out the same documents. Indeed, if PW Web complies the PW Explorer access control, they should be able to do the same with the same document on both platforms.
      The "Can Free" option in the PW Administrator configuration is checked and is the one that allows users to free their own documents, checked out by those users.
      The "Free" option of PW Explorer is only checked so that the documents can be freed even if those users have not checked them out themselves. That option has never been active except for administrators or specific users, but it does not prevent a user from discarding changes to their documents. If PW allow a Check Out, it should allow to Free, simply by having the Can Free box checked in PW Administrator.
      BR
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Chris Andrew
      0 Offline Chris Andrew Mon, Dec 7 2020 3:45 AM in reply to Aitor de la Fuente
      I think you may have discovered an issue.
      So if I'm reading this right. The user has checked a file out online (PW Web) and made changes by mistake and now wants to free.
      As Free is turned off in PWE I think this is why it's not available in PW Web.
      In PW Web what are the Check in options visible by the user?
      Chris
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Offline Aitor de la Fuente Mon, Dec 7 2020 3:52 AM in reply to Chris Andrew
      Only the Check in and the Update server copy options:
      If I set the Free option in the PW Explorer access control, I think the Free option would appear available, but wouldn't that also make it possible for any user to free documents that were checked out by other users? This would be a problem also....
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Chris Andrew
      0 Offline Chris Andrew Mon, Dec 7 2020 3:54 AM in reply to Aitor de la Fuente
      Not if the option is applied to the user. But yes if applied to a group or list.
      Audrius.Pundzevicius can you have a look into this?
      Chris
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
