Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Printing Rendition PDFs Missing Reference Files
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 61 subscribers
    • Views 1185 views
    • Users 0 members are here
    • Renditions
    • ProjectWise
    Taylor Brownlow
    Offline Taylor Brownlow over 3 years ago
    We are trying to print some plan sheets with multiple reference files nested in a motif file with a depth of 1. Most of the nested references are displaying on the PDFs but 2 files are not printing even though they are on in the motif file and are displayed correctly in the dgns. We tried to save the view in the files which did not help. Finally we exported all of the sheets with references to a local folder and printed from a local organizer and it worked fine.
    Any ideas why renditions is not printing 2 nested reference files? How do I see the settings of the ProjectWise renditions printing to troubleshoot?
    Thank you!
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Dec 11 2020 4:09 PM +1 verified
      Usually when I see missing references on Renditions it's because the references were attached directly from a server or local drive instead of via ProjectWise and the server can't find the file (your machine…
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Fri, Dec 11 2020 4:09 PM
      Usually when I see missing references on Renditions it's because the references were attached directly from a server or local drive instead of via ProjectWise and the server can't find the file (your machine can find the file because you happened to have a copy of it on your computer already.) Verify the attachment info of the missing references.
      Next most common is that the account doing the renditions doesn't have access to the references. If you're right-clicking and selecting Create Rendition yourself then this probably isn't the problem. if the rendition is running as part of an automated process it could be the issue.
      You can try using Local Document Organizer to purge everything off your machine, then use InterPlot Organizer to test creating the PDF local. Select the same set file that renditions uses and see what happens.
      Finally, you may need to work with whoever administers your rendition server, they can check the logs to see if it reports an error trying to copy out the reference.
      Answer Verified By: Taylor Brownlow
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Taylor Brownlow
      0 Offline Taylor Brownlow Fri, Dec 11 2020 5:12 PM in reply to Kevin van Haaren
      Thank you! This worked!
      "the references were attached directly from a server or local drive instead of via ProjectWise"
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Taylor Brownlow
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
