I am installing version 10.00.02.298 of ProjectWise Integration and Orchestration Framework. I select the installer for PrpjectWise Integration Server and select "Automated File Processing." I then configure the Orchestration Framework with the Domain, User, and User Password. I then select the ORchestration Framework database and install it. The Orchestration Framework installs and the service starts. However, the Integration Server does not install. I can install each component separately, but at the end of the installation, I receive the error, "Packages listed below are not installed successfully - ProjectWise Integration Server." I have the Connection client installed and logged in.
Should have said version 10.00.03.298.
Got it, I'm building a test server pair as we discussed for head-tail. I'll follow up through the service request with you.
Was there a resolution for this? We are running into the exact same issue right now, with the same version.
There were fixes introduced in Server 10.00.03.299 . Have you upgraded and rebuilt the Index Head/Tail pair using a fresh Orchestration Framework Database?
