This is a new occurrence of an old problem with no solution so far. A user is working in Power InRoads Ss10. After creating a file and adding references, they exit and when they try an open the files, once the session starts, the login to datasource dialog box opens. Logging in or cancelling seems to have the same results- the file never opens and the sessions exit.
A copy was made of the file and the process repeated and the same result occurs.
Further testing revealed that the file fails to open even if accessed from the working directory outside of ProjectWise. In that case, the desktop opens, but the file never loads. A limited number of toolbars load, but there is no main menu or views.
It was also discovered that the files will open in PowerInRoads Ss2.
Here are some of the log entries my PW sent me:
2021-03-24 08:30:08,808|DEBUG|0x000048f8|pwise.MCM|mcmDlg_openDocument @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcmmsh.c:5912 - Updating MCM active login info cache with database name "SHAVMPWX.shacadd.ad.mdot.mdstate:SHAEDMS01" and user name "ad\admin-emiller"]
2021-03-24 08:30:08,808|DEBUG|0x000048f8|pwise.MCM|mcmDlg_openDocument @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcmmsh.c:5921 - Calling post-hooks for mcmDlg_openDocument.
2021-03-24 08:30:08,808|DEBUG|0x000048f8|pwise.MCM|mcmMainDlg_openDocument @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcmmsh.c:4420 - User canceled open dialog or error occured (status = 2), restoring active datasource and exiting.
2021-03-24 08:30:08,808|ERROR|0x000048f8|pwise.MCM|MdlMain @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcm.c:3938 - An unknown error occurred either because the open document dialog was cancelled or information about the document could not be retrived. MCM will unload and PW integration will be disabled!
2021-03-24 08:30:08,808|INFO|0x000048f8|pwise.MCM|mcmMain_Uninitialize @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcm.c:3268 - Defining configuration variable _MCM_DISABLEINTEGRATION to signal integration disabled to other modules.
2021-03-24 08:30:08,808|INFO|0x000048f8|pwise.MCM|mcmMain_Uninitialize @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcm.c:3271 - MicroStation not started from ProjectWise Explorer. Unloading titleblocks ...
2021-03-24 08:30:49,623|DEBUG|0x00002be4|pwise.MCM.References|mdmMain_referenceAttach @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcmmsh.c:2146 - [SYSTEM_REFERENCE_ATTACH] skipping self-reference
2021-03-24 08:30:49,856|ERROR|0x00002be4|pwise.MCM|mcmMain_openInitialFile @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcm.c:2881 - Failed to open the specified design file "c:\pwdata\ad_admin-emiller\d1579297\mHD-0000_MD256-MD258.dgn". Exiting MicroStation!
2021-03-24 08:30:49,856|ERROR|0x00002be4|pwise.MCM|mcmMain_OpenDocument @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcmpublic.cpp:253 - Failed to open document with IDs (1579297, 1) and file path c:\pwdata\ad_admin-emiller\d1579297\mHD-0000_MD256-MD258.dgn
2021-03-24 08:30:49,856|INFO|0x00002be4|pwise.MCM|MdlMain @ e:\Builds\pw100003167\Source\dms\integration\ustation\mcm\v0811\mcm.c:3812 - Partner mode startup failed. Not a problem.
Have you tried copying the problematic File (from the ProjectWise Working Directory) to a different Windows Folder (ex. your Desktop) and open it from there (purposely to exclude References)? If you are able to open without any issue whatsoever, can you then try copying one Referenced File to the same Folder and open again? This is to either rule out a Referenced File issue or to identify the one that is causing the issue. I would then copy each of the remaining Reference Files and test them one at a time.
ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
ProjectWise Drive, Version 2022.1.328
OpenRoads Designer CONNECT Edition, Version 10.09.00.91
OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
The file does not open outside of ProjectWise either.
It is likely a damaged file somewhere among the root or it's referenced files.
But how do we find what is bad and fix it?
