ProjectWise Microstation Item Type Attribute Exchange
Hi all,
I am attempting to use the new ProjectWise Microstation Item Type Exchange but dont have any luck getting attribute values to populate. Microstation is seeing the ProjectWise Attributes though (just with blank values).
Is there any documentation or info that i can refer to to figure out whats happening? or anyone have any idea why the attribute values won't populate?
Mark
  • For me it was removing underscores and hyphens, from both the Attribute Class and the Attribute (PW Environment attributes don't need to change)
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Associate Director – Digital
    OpenRoads Designer 10.11 | MicroStation CE 10.17 | ProjectWise CE 3.4 | ContextCapture | ProjectWise PowerShell 2.0 | Generative Components | OpenBridge Designer 10.11
    Revit 2022 | Civil 3D 2022 | Recap 2022 | Infraworks 2022 | Dynamo | Navisworks Manage
    PowerShell | Visual Studio | Office 365 | Power Automate | Teams | SharePoint | Visio
    Speckle | BIMVision | Revizto | Solibri
  • Hi Mark,
    Please check the Expression definition once,
    The Expression is what creates the link to ProjectWise. Remember for the expression the format needs to be, ProjectWise.TitleBlocks..
    Also, uppercase and lowercase does not matter
  • It also appears my Managed Workspace is stopping it from working. Only works when I open in NoWorkset.
    I assume PW Managed Workspace is overwriting the mcm.cfg on my c drive
    Chris
  • Okay, so I can confirm that I have the same issue. Works perfectly without the Managed Workspace loaded. Not too sure what it could be.
    Mark
    OpenRoads Designer 2022 R1 (10.11)  |  Microstation CE Update 17.2 |  ProjectWise CE 3.4
  • I know this is a Tech Preview, but can someone from Bentley make a suggest as to how we get this to work when using a Managed Workspace.
    Chris
