Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum pwe will not open word documents 50002
    • Sign In
    • State Suggested Answer
    • +1 person also asked this people also asked this
    • Replies 10 replies
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 2311 views
    • Users 0 members are here
    • Projectwise Explorer
    • word
    • Windows 10
    • Application integration
    William Nelson
    Offline William Nelson over 2 years ago
    i cannot  get pwe to open word documents. I have check desktop integration, unistalled and reinstalled integration. I have checked the add-ins , that is all good. I even changed loadbehavior to 3. I removed associations for word. I have literally tried every thing listed. office 365, pwe connect 10.0.3.280
    • Sign in to reply
    • Cancel
    • Matt Kovach
      0 Offline Matt Kovach Mon, Jun 28 2021 4:59 PM
      Hello William Nelson,
      Have you checked the HKEY_CURRENT_USER Registry Hive as well (as the HKEY_LOCAL_MACHINE Registry Hive)? You mentioned checking the Load Behavior on the Add-ins.
      Here are some Keys to check for conflicting Add-in Load Behavior settings:
      • HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\Excel\Addins
      • HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\Outlook\Addins
      • HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\Word\Addins
      See if there are any PWOfficeAddIn.ConnectProxy_16 Subkeys. Try removing these, as there should be equivalents under the HKEY_LOCAL_MACHINE Registry Hive, with the proper Load Behavior setting.
      Hope that this helps
      ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
      ProjectWise Drive, Version 2022.1.328
      OpenRoads Designer CONNECT Edition, Version 10.09.00.91
      OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
      Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • William Nelson
      0 Offline William Nelson Tue, Jun 29 2021 8:54 AM in reply to Matt Kovach
      those keys do not exist in HKLM
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • William Nelson
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matt Kovach
      0 Offline Matt Kovach Tue, Jun 29 2021 8:59 AM in reply to William Nelson
      Do you see Keys here?:
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Office\Excel\Addins
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Office\Outlook\Addins
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Office\Word\Addins
      In addition to the PWOfficeAddIn.ConnectProxy_16 Subkey, you may also see the BSIPWOfficeAttr.AttrConnect.1 Subkey.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • William Nelson
      0 Offline William Nelson Tue, Jun 29 2021 9:02 AM in reply to Matt Kovach
      supposedly thats for 32bit. we have 64bit 10 and 64bit office but i did check there , there is addins but no pwofficeaddin
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matt Kovach
      0 Offline Matt Kovach Tue, Jun 29 2021 9:39 AM in reply to William Nelson
      Can you check this:
      Does this File exist in the Folder specified here? I'm a bit confused by the lack of PWOfficeAddIn.ConnectProxy_16 Subkeys in the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office Keys. From my experience and understanding, these Keys determine the Load Behavior (I have them and all Office Applications seem to work just fine).
      On a somewhat related note, we did have issues with ProjectWise Explorer version 10.00.03.280 and Office Applications. If you opened a Word File (for example) from a Windows Folder and then went to open a Word File (Document) from ProjectWise Explorer (by double-clicking on it), you would be prompted to sign into a Datasource again. This issue was fixed in 10.00.04.434 (not sure about 10.00.03.3xx versions).
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • William Nelson
      0 Offline William Nelson Tue, Jun 29 2021 9:43 AM in reply to Matt Kovach
      yes both projectwise addins are checked
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
