Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise revit advance integration
    • Sign In
    • State Suggested Answer
    • Replies 1 reply
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 385 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin over 2 years ago
    Hello All
    Anyone know the difference between the Location Backup and Location eTransmit?
    Both seems to behave the same and have the same configuration? Is the name the only difference?
    • Sign in to reply
    • Cancel
    Top Replies
    • Goda Kutkeviciute
      Offline Goda Kutkeviciute Fri, Jul 9 2021 3:37 AM +1 suggested
      Hi Luc, Both those folders could be used when eTransmitting a Revit file. Their roles however differ as they should be used for different purposes. The difference between them is that eTransmit location…
    • Goda Kutkeviciute
      0 Offline Goda Kutkeviciute Fri, Jul 9 2021 3:37 AM
      Hi Luc,
      The difference between them is that eTransmit location can have an environmental binding assigned to it. Meaning if you eTransmit a Revit file to eTransmit folder located in ProjectWise Explorer you can populate the ProjectWise Explorer document attributes with bound values from the Revit properties (such as Scale, Created By and others). As the Backup folder does not have such functionality it is intended to store the backups of the Revit documents.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Reply
    • Goda Kutkeviciute
      Hi Luc,
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
