Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum which pwc.log.xml?
    • Sign In
    • State Verified Answer
    • Replies 3 replies
    • Subscribers 62 subscribers
    • Views 654 views
    • Users 0 members are here
    which pwc.log.xml?
    Kevin van Haaren
    Offline Kevin van Haaren over 2 years ago
    I notice there is a pwc.log.xml file in both the 64-bit Program Files folder and the 32-bit pwc.log.xml Program Files (x86) folder. Do we need to edit both of these to change logging or just one of them? I assume the one next to the pwc.exe is the better one to edit?
    • Sign in to reply
    • Cancel
    Top Replies
    • Goda Kutkeviciute
      Offline Goda Kutkeviciute Fri, Jul 30 2021 1:48 AM +1 verified
      Hi Kevin, As ProjectWise Explorer is 32 bit application the pwc.log.xml needs to be modified at C:\Program Files (x86)\Bentley\ProjectWise\bin\ location only (the location where pwc.exe is). Modifying…
    • Matt Kovach
      0 Offline Matt Kovach Thu, Jul 29 2021 5:15 PM
      Hey Kevin,
      According to the latest Read Me (Release Notes section), it is the pwc.log.xml File within the C:\Program Files\Bentley\ProjectWise\bin Folder:
      Release Notes (bentley.com)
      ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
      ProjectWise Drive, Version 2022.1.328
      OpenRoads Designer CONNECT Edition, Version 10.09.00.91
      OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
      Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Goda Kutkeviciute
      +1 Offline Goda Kutkeviciute Fri, Jul 30 2021 1:48 AM
      Hi Kevin,
      As ProjectWise Explorer is 32 bit application the pwc.log.xml needs to be modified at C:\Program Files (x86)\Bentley\ProjectWise\bin\ location only (the location where pwc.exe is). Modifying the pwc.log.xml in Program Files will not change the logging level.
      Answer Verified By: Kevin van Haaren
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Matt Kovach
      0 Offline Matt Kovach Fri, Jul 30 2021 7:47 AM in reply to Goda Kutkeviciute
      Can the Documentation (i.e. Release Notes) please be revised to state as such (the correct path of the pwc.log.xml)? This could be helpful to others.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
