Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Create a note field as attribute
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 60 subscribers
    • Views 473 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin over 1 year ago
    Hello
    Any suggestion to create a note field as an attribute to allow users to drop some generic comment.
    I was thinking adding a VarChar of 1000 Charater, but it seem we are not able to use carriage return to create line.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Sep 24 2021 9:39 AM in reply to Luc Poulin +1
      1000 is what I typically give them. 500 if there are a lot of other long attributes. can't remember if Bentley worked around it but SQL Server has a limit of 8000 bytes per row, and a row for environments…
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Sep 22 2021 11:30 AM
      In the attribute properties, under the Editing tab set the Control type to multi-line edit field.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Fri, Sep 24 2021 9:24 AM in reply to Kevin van Haaren
      Thank you Kevin
      Any limit suggestion for the length?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Sep 24 2021 9:39 AM in reply to Luc Poulin
      can't remember if Bentley worked around it but SQL Server has a limit of 8000 bytes per row, and a row for environments is all the attribute lengths added together. But notice I said "bytes" and not "characters". Varchar type is unicode encoding, in unicode a character can be 1-4 (or more? can't remember now) so 1000 characters can be 4000 bytes, or 1/2 the space. I think the smiley face emoji I put in that example is a 4 byte encoding.
      If your users mostly use the English alphabet, most characters are 1 byte.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
