Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Email properties to attributes
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 61 subscribers
    • Views 550 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin over 2 years ago
    Hello
    How can we force older documents ( email export to projectwise) to have their attribute(s) update
    Example I wanted to have the FROM field from outlook to populate an attributes
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Oct 5 2021 11:18 AM
      force File Property Extraction to reprocess the files.
      in PW Admin, log into the datasource, Expand Document Processors. Right-click File Property Extraction and select Mark Folder Documents for Reprocessing. Select the folder, turn on Include subfolders if desired, click OK.
      It takes awhile for the processing to actually get started.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Tue, Oct 5 2021 1:48 PM in reply to Kevin van Haaren
      Just to make sure... In outlook we have the from field, is "from" will be the correct wording to extract the info and place it to an attributes?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Oct 5 2021 2:11 PM in reply to Luc Poulin
      Ah, File Extraction puts that info in the File Properties tab in Projectwise:
      I think you could write a powershell to pull that info from the File Properties and put it into an Environment Attribute, but I've never done it.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
