Good Afternoon All,
I have a strange issue that I have not been able to figure out. We have a View that happens to be the datasource default view that has the columns ordered as we want them. However when opening dialogs in ProjectWise Integrated Applications such as file open in AutoCAD or Microstation the first column (Name in this case) is not in the correct order relative to the view in both PW Administrator and PW Explorer. I have not been able to determine how to reset the order of the column in the view from inside that dialog. Again, the order is correct in PW Admin and PW Explorer.
Any help would be appreciated.Regards,Tim..
Right click on the column header in AutoCAD or Microstation dialog and you can choice the view. This should reset the column positions when you select your view
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Principal Engineer – Digital
OpenRoads Designer 10.10 | MicroStation CE 10.16 | ProjectWise CE 3.4 | ContextCapture | ProjectWise PowerShell 2.0 | Generative Components | OpenBridge Designer 10.10
Revit 2022 | Civil 3D 2022 | Recap 2022 | Infraworks 2022 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Automate | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Chris,Thanks for the suggestion. I have tried that previously but it does not reset the view. I would have thought the same.
Tim.
