Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Using %error directive in CSB
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 60 subscribers
    • Views 581 views
    • Users 0 members are here
    • ProjectWise
    • CSB
    • Configuration
    Ronald Koons
    Offline Ronald Koons over 1 year ago
    I am following the topic: "Dynamic Managed Workspace", by Buddy Branham.
    There is a .cfg file: WorkAreaPWSetup_Predefined_Example_CE.cfg, that is a part of this collection of resources that I believe is intended to be used as a .cfg, or converted into a CSB; both options in ProjectWise.
    There is a simple collection of code:
    %if defined (_VERSION_8_11)
    %error This WorkArea not configured for V8i.
    That I am trying to input into a CSB.
    The problem I am having is that the Flow Directive %error is not included as one of the options in ProjectWise.
    Likewise, "%if Defined", is also not an option, but here I can use %if, and then add the rest as string.
    An I supposed to somehow add the %error on the same string line, or is this just not possible?
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Nov 4 2021 6:45 PM
      in the configuration setting block Configuration tab click the + sign and select Add Directive
      click the drop down arrow for the directive and select %error from the drop down
      Add the error message you want as a string, click OK.
      The only directive that i'm aware is missing is a new one in Connect %echo that displays a message like %error but does not stop execution.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Nov 4 2021 6:46 PM in reply to Kevin van Haaren
      For %if defined (_VERSION_8_11) select %if and then the string is:
      defined(_VERSION_8_11)
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Nov 4 2021 6:48 PM in reply to Kevin van Haaren
      Oh yeah, if you're doing this in ProjectWise Explorer in your Personal Workspace CSB the directives aren't available. Have to do it in administrator.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ronald Koons
      0 Offline Ronald Koons Mon, Nov 8 2021 9:33 AM
      Thanks…
      I’ll just have to chalk it up to not paying attention, because now I see it there.
      Ron Koons
      EXP | BIM Manager
      t : +1.312.616.5002 | m : +1.708.510.7467 | e : ronald.koons@exp.com
      exp.com | legal disclaimer
      keep it green, read from the screen
      Ron Koons
      EXP | BIM Manager
      Chicago, IL
      USA
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
