Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ICS for PDF - Microstation SELECTSeries and CONNECT Print Engines
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 61 subscribers
    • Views 524 views
    • Users 0 members are here
    • MicroStation V8i
    • MicroStation Connect
    • iCS for PDF
    Tim Knaus
    Offline Tim Knaus over 1 year ago
    Hello all,
    Problem: I am attempting to have both Microstation SELECTSeries and CONNECT print engines available on our ICS server. I have configured MS CONNECT as the default print engine, however we have application types that will still refer to SELECTSeries Microstation for legacy projects. I would like to print SELECTSeries files with SELECTSeries and CONNECT with CONNECT. It seems that regardless of the Microstation application type on the document, MS Connect is the print engine that gets used on the ICS Server. Is it possible to utilize both MS print engines on ICS for PDF? We are on 10.00.03.299.
    Tim..
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Mon, Dec 20 2021 6:28 PM
      I think this is what you're looking for:
      I-model composition server and microstation connect & v8i - Content Publishing Forum - Content Publishing - Bentley Communities
      Basically setup an application in PW that only opens MicroStation V8i assign the V8i files to that application and Renditions should use V8i engine on the server.
      If you go to this message:
      ProjectWise Open document with dialog box - Content Management Forum - Content Management - Bentley Communities
      Towards the end of the thread i posted a table showing the Program Class name you can use to create an application that only opens MicroStation v8i SS10 (or SS4).
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Kevin van Haaren
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Tim Knaus
      0 Offline Tim Knaus Tue, Dec 21 2021 9:13 AM in reply to Kevin van Haaren
      Kevin,
      Once again thank you for your assistance. That worked perfectly! Much appreciated.
      Tim..
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
