Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum MS_SERVER cleared using PW
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 338 views
    • Users 0 members are here
    • Projectwise Explorer
    • MicroStation
    • Configuration
    Finn Mejding
    Offline Finn Mejding over 1 year ago
    Hi
    I am running MicroStation Connect updt. 16 and ProjectWise Explorer 10.00.03.434.
    I am having trouble connecting to a MS Access database when I have started MicroStation through ProjectWise.
    When I start MicroStation outside PW I can connect fine.
    Through PW the variable MS_SERVER is cleared. This happen when I press the Browse icon (the three dots) in the connect to database settings dialog.
    Before trying to connect:
    Then pressing Browse
    The result:
    I don't even get to browse for the ODBC name.
    The ODBC datasource is a 64 bit connection.
    Any other there have experienced something like this?
    • Sign in to reply
    • Cancel
    • M. Edeling
      0 Offline M. Edeling Fri, Apr 8 2022 3:35 PM
      SR 7000954139, describing that problem. The solution was:
      The key variable that was going undefined by ProjectWise was_USTN_DATABASE. In my network configuration files that open our ProjectWise environment,I added the following:
      _USTN_DATABASE = $(MSDIR)config\database\
      it might be that you also need to add MS_MDLAPPS < $(MSDIR)config\mdlapps\
      When you have ProjectWise managed workspace, just add these variables to the Global CSB.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
