HiIm investigating the possibility to move a old Document Management System to a ProjectWise datasource.The old DMS is a flat system without any folder structure. Basically document profiles with files.The old DMS consists of +500000 document profiles with files(and versions)
Are there any limitations of how many documents can exist in one single PW folder?Will this result in any performance issues?
So, technically is should work but the general recommendation is to not exceed 10000 documents in one single folder or something like thatThen we need to build a folder structure to accomplish this!Thanks for your answer Kevin van Haaren and Chris Andrew
