Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Purging Local Copies
    • Sign In
    • State Verified Answer
    • Replies 3 replies
    • Subscribers 62 subscribers
    • Views 1119 views
    • Users 0 members are here
    Lonnie Frater
    Offline Lonnie Frater over 1 year ago
    I am unclear as regards purging local copies. As an administrator I would like to try to understand the best practices.
    Allan asks a similar question https://communities.bentley.com/products/projectwise/f/projectwise-di-forum/227555/purge-copies-local-copies-still-intact
    As I understand it I can go to the document organizer for my own system, logged in as myself and view the copies and choose to purge them. This will delete the entry from the database and remove the file from the BMS directory. Correct? So this would be the ideal way to manage this?
    However as an administrator what happens with other users? As I understand it, I can
        1) from the document organizer - view the files copied out.
            a) however if I delete these it will only remove them from the database, correct?
            b) assuming I can with no detrimental effects remove them as above, am I free to simply delete bms files?
            c) is there a better way to manage this? Particularly in relation to other users.
       2) the option to right click a folder and purge copies, this is exactly the same result as going via the document organizer? Only limited to the folder (inc sub folders, if you choose) selected. I assume this is still only           for your user, correct?
    We have a number that hot desk or use different systems and as a result we need to try to manage disk space effectively.
    Thanks in advance
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, Apr 14 2022 11:32 PM +1 verified
      A file purge from Local Document Organizer will delete all files listed from the local machine, however some files aren't listed there. A) Managed workspace files are visible under the button that looks…
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Thu, Apr 14 2022 11:32 PM
      A) Managed workspace files are visible under the button that looks like some tools. They have to be purged separately.
      B) Files can be orphaned locally. Documents that appear in LDO are only ones that still exist in ProjectWise. So say UserA has done a bunch of work in Folder1 so they have all those files locally. UserB deletes Folder1. Now UserA has a bunch of files locally that don't have a matching document in PW. These files will not appear in LDO and won't purge.
      My recommendation to users is:
      1. check in or free all checked out documents.
      2. purge all copied out documents.
      3. purge all managed workspace documents
      4. Delete all the sub-folders in your working directory.
      if a user begins having problems after doing this, have them go through the steps again, then you use the CHKLCLEANUP utility to purge all chkl table entries for that user's computer. We haven't had to do this for any users in awhile.
      CHKLCLEANUP Instructions:
      communities.bentley.com/.../using-the-chklcleanup-utility-in-projectwise-tn
      Answer Verified By: Lonnie Frater
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Apr 14 2022 11:35 PM
      Oh, on point 2, yes this is correct. Selecting purge on a folder purges local files from those folders only, it has the same limitation that the file must exist in PW, files deleted (from PW) will not be purged.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Lonnie Frater
      0 Offline Lonnie Frater Fri, Apr 15 2022 12:16 AM in reply to Kevin van Haaren
      Excellent Kevin,
      Thank you for taking the time to confirm. So I am not missing anything we must just manage as we see it.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
