Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Batch Job using Renditions
    • Sign In
    • State Suggested Answer
    • Replies 4 replies
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 563 views
    • Users 0 members are here
    Richard Garcia
    Offline Richard Garcia over 1 year ago
    Is is possible to create a set of dgn files to run renditions on? Currently we are selecting all files in ProjectWise, right click, create renditions. Is there a better way to go about this?
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Apr 20 2022 1:27 PM
      Interplot Organizer can create IPS files to submit to renditions. Very similar to print organizer PSET files.
      interplot organizer is included in your Projectwise license (but is an additional install, it's not built-in) so no cost to use.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Richard Garcia
      0 Offline Richard Garcia Wed, Apr 20 2022 2:08 PM in reply to Kevin van Haaren
      Is there a go by for this that you are aware of? Something I can use for instructions.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Edge
      0 Andrew Edge Wed, Apr 20 2022 2:36 PM
      ProjectWise saved search.  Can either right-click on the search results in PW Explorer and Create Renditions, or set up a stored job in iCS Admin to run on a schedule using the saved search as the input set.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Apr 20 2022 3:40 PM in reply to Richard Garcia
      Intstall InterPlot Organizer from Software Downloads, open the ProjectWise InterPlot Organizer CONNECT Edition Help. There isn't any documentation at docs.bentley.com (although i've asked for it). It's very similar to Print Organizer (except it doesn't have those folders that Print Organizer does)
      Andrew's suggestion of a saved search is a good idea as well, if you're just wanting a quicker way of selecting all the appropriate files instead of picking and choosing them. This is probably fastest. We do a lot of them. Generally the saved search is either:
      1. Filename based such as *sheet*.dgn
      2. Folder based: *.dgn in folder X and all sub-folders
      3. Environment based - we create an attribute in the environment "include in plot set". they toggle that on and the saved search finds them.
      Make sure you have your searches set to return only the current version or you'll get a plot for each file version.
      • Cancel
      • Vote Up -1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
