Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum How can I open open locally saved drawing with ProjectWise managed workspace?
    • Sign In
    • State Not Answered
    • Replies 6 replies
    • Subscribers 62 subscribers
    • Views 844 views
    • Users 0 members are here
    Christopher Johnson
    Offline Christopher Johnson over 1 year ago
    We have a ProjectWise managed workspace, that we use when editing drawings in ProjectWise.
    Occasionally, I want to save a copy of a file locally to experiment or demonstrate a skill without risk to changing the ProjectWise version.
    In other words, sometimes I want to edit an non-managed exported drawing.
    Is there a way open a dgn on my C drive using a ProjectWise managed workspace?
    Right now I always get an error that the workspace the dgn was created in is not available
    • Sign in to reply
    • Cancel
    • Matt Kovach
      0 Offline Matt Kovach Thu, May 5 2022 12:18 PM
      Hello Christopher,
      I believe that you cannot do this (been I will since working with a fully Managed WorkSpace-based Work Area though). You would need to "recreate" your WorkSpace outside of ProjectWise. Additionally, you would need to export your WorkSet Configuration and DGN WorkSet Files...or recreate them as well. I am happy to be wrong though.
      ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
      ProjectWise Drive, Version 2022.1.328
      OpenRoads Designer CONNECT Edition, Version 10.09.00.91
      OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
      Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, May 5 2022 12:50 PM
      I didn't thoroughly test this method but it appeared to work for me (in MicroStation connect at least)
      1. Open a file from ProjectWise with the managed workspace
      2. Go to open a file and hit cancel on the ProjectWise explorer dialog
      3. The regular file browser* should open, use that to open the file on your hard drive
      4. When I did this with one of the example files from MicroStation Connect it prompted me to change the file branding from the example workspace to the one i tested with
      I selected to use the active workset (which is the managed workspace I'm using) and none of the workspace changed but the file opened. That's as far as I tested.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, May 5 2022 12:51 PM in reply to Kevin van Haaren
      Oh, the * on "the regular file browser will open" because this can be disabled by PW Admins. If it doesn't appear for you you'll need to contact them to allow it.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Christopher Johnson
      0 Offline Christopher Johnson Thu, May 5 2022 1:35 PM in reply to Kevin van Haaren
      Thanks for your reply.
      This does seem to work as a workaround.
      There is a caveat, the drawing I open in ProjectWise has to be a checked out and editable drawing i.e. not view or open as read only.
      Otherwise, MicroStation appears to stay stuck in read only mode.
      I am lazy :-D so I still wish I could just open directly from C drive, especially for opening multiple local drawings at the same time.
      But it is nice to at least have a workaround.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Offline Christopher Johnson Thu, May 5 2022 1:37 PM in reply to Matt Kovach
      I was afraid this might be the answer.
      Because of our strict cyber security, I can't add anything to the program files folders, which would make this even more difficult.
      Also, our workspace files are very fragmented, and despite my complaints, I can't convince folks to clean it up (lots of files that arn't used anymore at all).
      I think I could get it done, just would take lots of effort.
      I'll keep this idea in my back pocket though.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
