Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum [PW Explorer] Force Default Program at Work Area Level
    • Sign In
    • State Verified Answer
    • Replies 3 replies
    • Subscribers 61 subscribers
    • Views 723 views
    • Users 0 members are here
    Jennifer Miedema
    Offline Jennifer Miedema over 1 year ago
    Is it possible to force a PW work area to only open MicroStation V8i?
    I have a datasource set up with a dynamic workspace and the work area linked to a V8i workspace; however, many of the users have both MicroStation V8i and Connect installed and are new to working in ProjectWise. I don't want to force things at a datasource level as there will be other work areas that require using MicroStation Connect.
    Albeit having MicroStation V8i set as the default program for the datasource [see Image 1], when users initially attempt to open the file through ProjectWise the file attempts to open with Connect instead and the dynamic workspace creates an error [see Image 2] (purposefully written into the config by Bentley) when file tries to open with the wrong version of MicroStation. This is causing users a decent amount of frustration, and I'd just like to smooth over this hiccup and make their day easier and work a tiny bit more efficient (vs. always using the "Open with..." as a precaution).
       Image 1
      Image 2
    Issue is that I don't know if there's a way to create a configuration block in PW that will be read before anything else and if there's a PW or MicroStation variable that is at the system level for this.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Tue, May 10 2022 10:27 PM +2 verified
      Unfortunately you can't force a particular application at the work area level. Here's what I've been doing, it's not a great solution but it's a step forward. I create an Application for each version…
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Tue, May 10 2022 10:27 PM
      Here's what I've been doing, it's not a great solution but it's a step forward. I create an Application for each version and set the default application to open when a document is assigned that application. Then when I setup a work area i take any dgns already in the workarea and assign them to the proper application. I make sure the project's seed files are also set to use the proper application.
      That mostly makes files created using the seed file or copied from another file in the project work ok, but files dragged into projectwise will be assigned whatever application has set as the default for the dgn extension (user's can change which application is assigned to files they drag into projectwise in Tools > Associations > File Extensions...),  generally teaching users to assign the application works fairly well, but I also create a Global Saved Search in the Work Area to show all files assigned to each application in the Work Area. Users can use this to find dgn files assigned to the wrong application and used the Modify command to bulk change them.
      To create applications that launch a specific version of MicroStation I use the version specific program class name. The Program Class Names for MicroStation v8i and connect are:
      v8i:
      Bentley.MicroStation.Application.{B1E9E1E2-213C-47e5-BDD0-6A528DAE0244}
      Connect:
      Bentley.MicroStation.Application.{39949BF5-7E21-4A7B-A640-6E7199B7D588}
      Open Administrator and start creating a new Application (I created MicroStation V8i and MicroStation Connect):
      Click the Create button, verify the Action is set to Open, enter a Program Description and click the ... button
      Enter the Program Class Name for the appropriate version
      Click OK on this dialog and the Create Association dialog
      Now create the open action for MicroStation Connect (you want both listed so you can still open files assigned to the wrong application).
      After creating that application, make sure the appropriate version (V8i in my example) is set as Default (has the black diamond next to the name)
      Once you've created the V8i application you can copy/paste it in the Application list to duplicate it. Edit that copy, rename the application name and change the default to MicroStation Connect.
      I didn't show it here but I set the MicroStation V8i icon to V8i's icon and Connect's icon to the MicroStation Connect icon. This lets users quickly tell at a glance which application the file is assigned to.
      Answer Verified By: Jennifer Miedema
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Jennifer Miedema
      0 Offline Jennifer Miedema Wed, May 11 2022 6:31 PM in reply to Kevin van Haaren
      Hi Kevin,
      This works!
      I hit a bit of a blocker when I went to test it and things were still defaulting to MicroStation Connect albeit having MicroStation V8i selected, but then I checked my program associations in PW Explorer and my user associations were a mess. I had Connect as the default in the MicroStation V8i so deleted all the user associations and it works great.
      Out of curiosity, do you set any program extensions for applications? we had some set for MicroStation, but being that extensions can only be associated with one application I'm assuming it's best to not set them when having to MicroStation applications?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Mon, May 23 2022 11:45 AM in reply to Jennifer Miedema
      Sorry, got swamped and couldn't get time to answer this.
      Basically I still have a "MicroStation" application and I have all the products in there and make it the default for all the extensions. The product specific ones don't have anything listed for the file extensions.
      I think show users how to go into Tools > Associations > File Extensions... and set their own default for dgn/cel/etc... files. That setting overrides the default setting in the Application definition.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Kevin van Haaren
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
