Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Data type
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 61 subscribers
    • Views 700 views
    • Users 0 members are here
    Data type
    Luc Poulin
    Offline Luc Poulin over 1 year ago
    Hello Community
    Looking at a detail description of each Data Type we can choose when creating Attributes.
    I wanted to better understand long terms impact when selecting one versus another and the difference between them.
    I also see NatIve Data Type as an option??
    Thank you
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Jul 12 2022 11:06 AM
      The data types are specific to the database server you are using. If you are using SQL Server as your database most of the data types are here:
      https://docs.microsoft.com/en-us/sql/t-sql/data-types/data-types-transact-sql?view=sql-server-ver16
      there is also a good list here:
      https://www.w3schools.com/sql/sql_datatypes.asp
      Turning on native datatypes allows you to type in one of the data types for your database server that isn't in the drop down list. I would avoid this until you are very, very, sure of what you are doing (I've still never done it)
      Generally I use 3 types:
      • NVARCHAR - Text
      • INT - "small" numbers => max/min of +/- 2 billion
      • BIGINT - "big numbers" => max/min of -9,223,372,036,854,775,808 to 9,223,372,036,854,775,807
      Occasionally i use CHAR with a length of 1 to store Y/N values, but the logic on that gets hard, i probably should start using BOOLEAN for those types (that's a native type though)
      SQL Server has a maximum row length of 8000 bytes so you want to pick INT (4 bytes/number) and BIGINT (8 bytes/number) for the appropriate data you're using. Undersizing is hard to fix. I generally only need BIGINT when storing file sizes in bytes or time stamps in milliseconds, other engineering applications may have more use cases.
      the NVARCHAR and NCHAR are the datatypes for unicode strings. I prefer this as it handles a much wider range of characters correctly (including emoji) better. Setting the length of NVARCHAR is tricky. I usually estimate the biggest string I plan on storing and double that. Generally I pick 25, 50 or 100 unless it's a generic "comments" or "notes" field in which case I'll usually go to 200 or even 500. People names and Company Names I think I usually pick 50. Not sure if I've gotten burned on that yet. email typically 50 but I may start using 100, there are some incredibly long email addresses.
      Here's microsoft's info on NCHAR and NVARCHAR.
      docs.microsoft.com/.../nchar-and-nvarchar-transact-sql
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Jul 12 2022 11:08 AM in reply to Kevin van Haaren
      Oh, DOUBLE is for decimal numbers. Forgot that one. i don't usually use it.
      Also, beware the trap of thinking somethine will always be a number, you'll get burned when it suddenly isn't (for example, US Zip codes suddenly adding a -#### to the end of what was a 5 digit number). I also never store phone numbers as numbers, always strings.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Wed, Jul 13 2022 7:58 AM in reply to Kevin van Haaren
      Thank you Kevin
      Much appreciate
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • JessicaReed Reed
      0 Offline JessicaReed Reed Thu, Feb 2 2023 10:55 AM in reply to Kevin van Haaren
      Hi there! I understand where you're coming from; choosing the right data type can greatly impact your data analysis. It's good to take the time to really understand the difference between each option and what their long-term implications might be.
      Regarding the "Native Data Type" option, I'm not sure what that specifically refers to in your context, but you might also want to consider taking a look at some resources on how to choose data integration tools. It can help you understand what factors to consider when evaluating different data integration solutions and help ensure you're making the best choice for your needs. how to choose data integration tools
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
