Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Workflowing a DGN state to state is very slow using ProjectWise Explorer Client version 10.00.03.453
    • Sign In
    • State Not Answered
    • +1 person also asked this people also asked this
    • Replies 12 replies
    • Subscribers 62 subscribers
    • Views 753 views
    • Users 0 members are here
    Andrew Beer
    Offline Andrew Beer over 1 year ago
    Workflowing a DGN drawing from from one workflow state to the next state is very slow using ProjectWise Explorer Client version 10.00.03.453.
    It is taking about 30 seconds, where-as with ProjectWise Explorer Client version 08.11.11.590 it takes 2-3 seconds.  They use the same common ProjectWise Server version 10.00.03.140 in the backend.
    Something is wrong with version 10.00.03.453.  Not sure if earlier 10.00.03.XXX versions are like that or not.
    I'm trying to use that version as we are going to move to the latest MicroStation CE update, from the Select Series 10 version we are currently using. So ProjectWise Client version 10.00.03.453 is the latest version listed in the compatibility matrix for ProjectWise and MicroStation CE update 16.
    Can anyone help.  Thanks.
    Regards, Andrew Beer
    • Sign in to reply
    • Cancel
    • Andrew Beer
      0 Offline Andrew Beer Tue, Jul 26 2022 8:33 PM in reply to David Nicholson
      Hi David,
      We are using the Workflow Rules Engine.  Thanks for your comments on that.  Because we have no issues with the old ProjectWise Explorer Client version 08.11.11.590, which is pointing at the exact same server, it makes me wonder what has changed in the new PWE client to cause the issue.
      Cheers, Andrew
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Sujaan Fareed
      0 Offline Sujaan Fareed Tue, May 23 2023 4:38 PM
      Hi Andrew,
      We have done extensive testing to identify several performance issues with PW 04.434 and suspect similar problems with later versions. We have had to roll back. Bentley has been telling me we are the only customer complaining, but I see that is not the case.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Beer
      0 Offline Andrew Beer Tue, May 23 2023 4:56 PM in reply to Sujaan Fareed
      Hi Sujaan,
      We are currently using PW Explorer client 10.00.03.271, which allows us to use MicroStation CE release 17 and our older ProjectWise Server version 10.00.03.140 in the backend.  It's OK but a couple of slight bugs that we have to work around, but not an issue really.  The work flowing is a little slower than it used to be, but not as bad as with PW Explorer client version 10.00.03.453.
      We will eventually update our ProjectWise Server backend, then maybe client version 10.00.03.453 or later will work OK.
      What PW server version are you using ?
      Cheers, Andrew
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Sujaan Fareed
      0 Offline Sujaan Fareed Tue, May 23 2023 5:02 PM in reply to Andrew Beer
      Server is 3.721 and did not notice much difference after that update. Bentley was able to verify the issue is related PW Client software specific to versions higher than 03.434 including 03.453. Our primary case of testing has been folder navigation, and we see longer times with folders that have PW Environments assigned.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrew Beer
      0 Offline Andrew Beer Tue, May 23 2023 5:18 PM in reply to Sujaan Fareed
      That is interesting.  You say you're on Server version 3.721.  But it seems the latest ProjectWise Design Integration Server that can be downloaded from the Bentley downloads is 10.00.03.334.  Have you got a later version off Bentley's ?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
