Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Preference setting is not saving
    • Sign In
    • State Suggested Answer
    • Replies 4 replies
    • Answers 1 answer
    • Subscribers 62 subscribers
    • Views 588 views
    • Users 0 members are here
    Sunil Patil
    Offline Sunil Patil over 1 year ago
    Hi
    I am working in bentley projectwise and i am trying to do the below settings in my preferences but this setting is not holding everytime I have to open the file and do this setting again and again
    but when i open this files outof projectwise in local drive I can see the setting is already there is there any answer on this
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, Aug 11 2022 7:07 PM +1
      It's not mentioned in the MicroStation docs, but since MicroStation Update 13 there is a variable that controls this: _USTN_TEXTFIELD_BACKGROUND_PREFS The description of how it works is in the wiki:…
    • Jon Summers
      0 Offline Jon Summers Thu, Aug 11 2022 2:40 AM
      Move your question to the ProjectWise Forum.  Use the More->Move button to move your post.
      Remember to tell us both the version of MicroStation and the version of ProjectWise that you are using.
      What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
      See this blog that shows you how to obtain MicroStation's version number.
      Regards, Jon Summers
      LA Solutions
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Leonard Jones
      0 Offline Leonard Jones Thu, Aug 11 2022 4:01 AM
      Preference settings are stored in the Personal.UPF file under following folder. Check UPF related
      C:\Users\{UserName}\AppData\Local\Bentley\MicroStation\10.0.0\prefs\
      Check with your ProjectWise Administrator if Managed workspace has been setup and if this file is overwritten during product start.
      Make the required Preference changes, monitor file Personal.UPF (check timestamp). Restart the product and check if the Personal.UPF is overwritten.
      Create MSDEBUG, Show Configuration logs of standalone MicroStation and ProjectWise and compare the UPF file location.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Sunil Patil
      0 Offline Sunil Patil Thu, Aug 11 2022 7:53 AM in reply to Leonard Jones
      I intimate them Thanks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Thu, Aug 11 2022 7:07 PM
      Changing the Text Field background preferences - MicroStation Wiki - MicroStation - Bentley Communities
      This variable overrides what you have in your user setting. I suspect you have a managed workspace and whoever maintains the workspace has it set to 0 which forces both checkboxes to OFF.
      You can confirm this by using the key-in Show Configuration and then searching the text file that is opened for the variable. If the variable is not in that file then this isn't the problem.
      If this is the problem you'll have to contact whoever maintains the managed workspace. They can remove the current setting which will allow each user's preference to apply, change the setting to your preference (assuming they think it's appropriate for everybody), or %undef the variable for just you.
      The reason it works when you open the file outside of ProjectWise is there is no managed workspace and that variable isn't defined by default.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
