Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Error 58218
    • Sign In
    • Replies 10 replies
    • Subscribers 59 subscribers
    • Views 7007 views
    • Users 0 members are here
    Error 58218
    Scott Soper
    Offline Scott Soper over 14 years ago
    PW 08.08.04.50
    I have an office that is running into a few users with error 58218 - Check out location is already in use.  At first they tried Purging local files (through the Organizer), then deleting DMS folders.  I think for awhile, this would work but then even that didn't help.  If I change the location of the local working directory, it seems to go away but then comes back.
    It seems to me that something in the database is faulty.  Is there anything I can do to the database like a "compress"?
    • Sign in to reply
    • Cancel
    • Scott Soper
      Offline Scott Soper Wed, May 6 2009 7:10 PM
      I should have mentioned that we are running ProjectWise Server - 08.09.04.50 - the user was running ProjectWise client 08.09.40.63 but after these latest issues he loaded 08.09.04.116 but it didn't seem to make a difference.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Michael Dougherty
      Offline Michael Dougherty Wed, May 6 2009 8:55 PM in reply to Scott Soper
      See what the SQL returns.
      • Cancel
      • Sign in to reply
      • Cancel
    • John Schown
      Offline John Schown Thu, May 7 2009 1:27 AM in reply to Michael Dougherty
      Scott,
       ProjectWise tracks what it thinks is in the user's local working directory in a database table called dms_chkl.  There are three critical pieces of information that must be unique  for every entry in that table (file, node and working dir path). THis means no two users can copy a file out on the same node(computer) into the same working directory location. This is to prevent accidental overwriting of files and other potential data "confusion".
      Sounds like what may be happening is somehow another user is copying files out on that same computer.  Michael's suggestion of the SL statement to run may help identify if that is the case.  Potential ways this might happen might be a admin user logging in on that PC, or a change in Active Directory, or possibly even some customization or utility that runs as some other user then the normal windows user that works on that computer.
      HTH,
      • Cancel
      • Sign in to reply
      • Cancel
    • john.lee
      Offline john.lee Tue, Apr 8 2014 2:12 PM in reply to John Schown
      In the updated ProjectWise builds 08.11.07.xx or higher versions, the CHKLCLEANUP Utility is available and can be used to correct the following issue in the database:
      A user has many files checked\copied out and their system crashes beyond repair. Users using the same machine have the same ProjectWise-working directory. When one user tries to checkout a file that the other user has copied out, he may get an error. "Working directory is in use" or Error 58218.
      For a detail Overview, Please see the link to the Article “Using the CHKLCLEANUP Utility in ProjectWise”:
      http://communities.bentley.com/products/projectwise/content_management/w/wiki/5520.aspx
      • Cancel
      • Sign in to reply
      • Cancel
    Reply
    • john.lee
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
