Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Integration with Batch Processor
    • Sign In
    • State Not Answered
    • +1 person also asked this people also asked this
    • Replies 0 replies
    • Subscribers 61 subscribers
    • Views 188 views
    • Users 0 members are here
    Kevin van Haaren
    Offline Kevin van Haaren over 1 year ago
    Tested with:
    • ProjectWise Explorer 10.00.03.453
    • MicroStation CONNECT 10.17.00.209
    Not sure if this is a ProjectWise issue or a MicroStation issue, but i suspect it's ProjectWise integration problem.
    1. In PWE Check out a batch processor command file you'll be using. (Command files are just text files)
    2. Open a microstation dgn file
    3. Start batch processor, select a couple of dgn files & the command file you're currently editing.
    4. Run the batch processor
    5. Close the batch processor
    6. The file you had checked out before starting this whole process is automatically checked in with no prompt.
    If you don't notice the check-in at step 6 and make some more changes to the batch file depending on your "Use up-to-date local copy on check out/copy out" settings your changes will be overwritten the next time you run the processor.
    If you catch it before the local file gets overwritten it can be tricky getting the changes back into PW.
    • Sign in to reply
    • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
