Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise folder won't show up when trying to open a file in POWER Geopak?
    • Sign In
    • State Not Answered
    • Replies 5 replies
    • Subscribers 63 subscribers
    • Views 604 views
    • Users 0 members are here
    • ProjectWise
    David Ruiz
    Offline David Ruiz over 1 year ago
    Hi, I've been trying to solve this problem since Geopak won't let me attach any reference or open any document since the file explorer its empty. Any suggestions? Thanks.
    • Sign in to reply
    • Cancel
    • MaryB
      0 Online MaryB Thu, Sep 22 2022 7:16 PM
      This is a Printing forum. you need to move your post to the ProjectWise forum. Hopefully someone there can help you.
      MaryB
      Power GeoPak 08.11.09.918
      Power InRoads 08.11.09.918
      OpenRoads Designer 2021 R2
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Matthew Kovach
      0 Offline Matthew Kovach Tue, Sep 27 2022 11:54 AM
      Hello David,
      It appears (from the looks of your posted screenshot) that you are running these Bentley programs on Windows 11. Am I correct? In any case, it should be noted the the V8i generation of Bentley programs, including the current/latest version of ProjectWise Explorer and Power GEOPAK V8i (SELECTseries 10), are not certified to run on Windows 11 (the V8i products will likely never see a certified version). A future version of ProjectWise Explorer will support Windows 11 (no knowledge of release timing).
      Matthew Kovach
      Design Systems Administrator
      ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
      ProjectWise Drive 2022.1, Version 2022.1.638.0
      OpenRoads Designer CE 2021 Release 2, Version 10.10.21.04
      OpenRoads Designer CONNECT Edition, Version 10.09.00.91
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gary Turner
      0 Offline Gary Turner Wed, Sep 28 2022 12:45 PM
      David,
      We have been experiencing a similar thing when accessing a datasource hosted by another company via our gateway/cache servers.  You are able to open a file and it correctly opens any referenced files but if you try and attach a new reference it comes up blank.
      If we go direct to the external datasource rather than going via the gateway/cache servers then we are correctly able to attach new files form within ProjectWise.
      I haven't gotten to the bottom of it yet but if I manage to work it out I will let update this ticket.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • David Ruiz
      0 Offline David Ruiz Tue, Oct 4 2022 9:40 AM in reply to Matthew Kovach
      Good morning Matthew,
      I was not aware of this information. I am running it on windows 11! I will try to remain updated on that ProjectWise version on windows 11. Thanks for the information. Have a great day.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • David Ruiz
      0 Offline David Ruiz Tue, Oct 4 2022 9:41 AM in reply to Gary Turner
      Good morning Gary,
      This is a good method that I will try today. As Matthew mentioned in the comment above I am using Windows 11 and will need the update for it to work as it should. Thank you very much on the update and please keep the ticket posted if you happen to find something else! Thank you very much for your time.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
